SIMPLICITY LAWN TRACTOR
   / SIMPLICITY LAWN TRACTOR #1
jbrewer
CENTRAL OHIO
ALLIS CHALMERS MODEL B,KUBOTA 2410,1970 JACOBSON 1200 SUPER CHEIF
I HAVE A SIMPLICITY LAWN TRACTOR WITH A 16 H.P.BRIGGS & STRATTON MOTOR. I GET SPARK, BUT WHEN THE PLUG IS OUT THE MOTOR WILL TURN TURN FREELY. WHEN THE PLUG IS IN THE MOTOR IT WILL TURN OVER A FEW TIMES AND THE MOTOR STOPS TURNING. I WAS USING JUMPER CABLES CONNECTED DIRECT TO THE STARTER W/O A BATTERY. I DON'T KNOW IF THAT MATTERS. I WOULD APPRECIATE ANY AND ALL ADVICE. THANKS JERRY
   / SIMPLICITY LAWN TRACTOR #2
If you are sure the battery you are using is good, then I would remove the starter & have
it checked.
   / SIMPLICITY LAWN TRACTOR #3
If your hearing a clicking sound and the motor not turning you may have dirty batery post also starter post,just clean them up real good.
Maybe the battery to weak and time to replace,to be on the safe side I would have the battery check out.
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
