Simple green vs paint finish
   / Simple green vs paint finish #1
Carl Bert
Platinum Member
Rockland county, New York
Kubota B26, John deere X595
I was recently reading a thread in which the guy said he used "simple green" to clean around the grease fittings on his tractor. Well I tried it and was amazed at how well it worked. Has anyone else out there been using this product, if so does it have any long term effect on the paint finish?
Hopefully it's safe. I love the fact that I can finally walk around my tractor, check fluids or whatever, without having to worry about getting grease smeared on some part of my clothes
   / Simple green vs paint finish #2
The only thing I know is that SG is corrosive to aluminum. Just rinse well.
   / Simple green vs paint finish #3
I do know that Simple Green needs to be mixed properly or it can leave a noticeable residue/film after drying. My operation (totally unrelated to ag) has been using it for commercial cleaning but is moving away from it for this very reason.
Never heard about it being corrosive to aluminum, but.........
   / Simple green vs paint finish #4
I've used it quite a bit around the house/shop. As I recall, it cleans by getting between the dirt and the surface under it. I can ususally recall the name of this property but can't seem to at the moment. I've used it on lots of things where I just sprayed in on and rised with water 5 minutes later. It has been amazing how much dirt it will take off so easily. Works good on getting greese off the kitchen stove too. I think they have a caution about it can take off paint sometimes but I've never had it happen. I can certanly see how it could if it can get between the paint and the substrate. I never had any problem with aluminum and the msds sheet on the web site says it doesn't have a problem with any know materials. I think canada my be thinking of a different product. Check out their website, it is an interesting company, wiki also has information about a contravesy over the environmental friendlyness of the product. Yes, it does leave a slight film that can easily be removed with a wipe or splash of water. Breathing the fumes from it may not be the healthiest thing in the world for you, it seems to irritate my throat/lungs if I breath in the fumes/vapors, so regardless of the msds sheet claim that it has a low health risk I try not to breath it.
   / Simple green vs paint finish #5
Are you referring to a surfactant?
Used to reduce the surface tension, common in cleaners such as 409, Fantastic and other spray and wipe cleaners.
   / Simple green vs paint finish #6
Purple Stuff, and any of the other Purple Power, etc, are corrosive to aluminum, but I have never heard that with Simple Green.
   / Simple green vs paint finish #7
Sorry, not thinking about another product. The FAA has released a warning about it to aircraft owners (like me). Lots of owners were using it to degrease the bellies of thier airplanes. It can cause corrision in aluminum. Now they have actually made a aircraft version but you wouldn't be buying that at Wal-Mart.
   / Simple green vs paint finish #8
I have learned something new today, I can knock off and watch some golf now! Thanks, for the info, I had never heard that it could cause embrittlement in the aluminum alloys. Still probably ok for tractor use, but the caution to rinse well is good advice.
   / Simple green vs paint finish #9
I've been using simple green since it came out 25 years ago. It's what I wash all my cars, trucks, tractors, motorcycles, bicycles etc etc etc. It's the best all around general purpose cleaner IMO. and it doesn't make the worms come out of the ground.
Never had a negative issue, it's not the most powerful degreaser of course since it's biodegradable, but used straight does pretty good.
I buy it by the gallon and dilute for general cleaning, just takes a little in a pail of water to make suds. I also keep a spray bottle full of it straight for tougher cleaning tasks.
When it first came out I heard the salesmen told people it was so safe you could drink it. Not sure if anyone every did :)
JB.
   / Simple green vs paint finish #10
Yep, it is especially bad when you have overlapping joints (like on airplanes) where the stuff can seep into and start corroding.
I would think that on tractors it's not so bad, would not use SG on my plane though.
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
INGERSOLL RAND  G90 GENERATOR (A53843)
INGERSOLL RAND...
MISC WRENCHES (A53843)
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
