Simple Green Extreme - anyone
   / Simple Green Extreme - anyone #11
A pressure washer works surprisingly well without any degreaser.
   / Simple Green Extreme - anyone #12
Have you looked into their rig wash product?
Simple Green Rig Wash
I was introduced to simple green when I worked at airports as well. I remember we had to wash the planes from the bottom up. If you washed it from the top down, the simple green would leave lighter streaks on the lower parts as it would run down the sides and sit in one area longer than others. Really noticeable on white planes.
And as others have mentioned... planes get filthy! :p Way worse than cars. Kinda strange how much grease and oil gets on them. And its disturbing to see that oil streaking down the sides of the nacelles. YIKES!! You fly in that thing? Its one thing to see a crapped out Chevy dripping in your driveway. You can pull over if the engine quits. Try that in a plane! :laughing: And you can't run them down to the car wash very easy, either. ;)
   / Simple Green Extreme - anyone #13
Wondering what the difference is between Simple Green and Simple Green Extreme...
Simple Green
Ingredients
Water, Ethoxylated Alcohol, Sodium Citrate, Tetrasodium N,N-bis(carboxymethyl)-L-glutamate, Sodium carbonate, Citric Acid, Colorant, Fragrance.
Ingredients
Water (Aqua), Triethanolamine, Ethoxylated Alcohol (and) Quaternary Amine, Propylene Glycol Butyl Ether, Tetrapotassium pyrophosphate, Sodium Silicate.
   / Simple Green Extreme - anyone #14
I hit it with the pressure washer about four times a year. The only thing that does not come off is the exhaust soot. That yields to WD-40 on a rag. Keep in mind, I try and keep it cleaned off. Not show room clean but presentable clean. A "clean" piece of equipment is easier to identify fluid leaks on than a dirty one.
Sedan (A59231)
Sedan (A59231)
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
SKID STEER ATTACHMENT PACKER (A58216)
SKID STEER...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A58375)
UNUSED SDLANCH...
Utility Cart (A59228)
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
