Simple farm tractors are history
   / Simple farm tractors are history #31
The problem with those old Yanmars is they only made compacts, not utility sized machines. And this thread is about farm tractors.
My YM2610 is more than a compact, it is a farm tractor. Back in the day a Ford 8N was the work horse farm tractor. My machine is a notch greater for power and ability in the same size.
The YM5000, YM6000, and YM7000 are the Deere JD1250, JD1450 and JD1650.
Go back and look at the classics, those are the machines America used as "Simple Farm Tractors."
Yes, this is the Yanmar compact you are referring too.
   / Simple farm tractors are history #32
Yes but I’ve never seen a red Yanmar of that size and you were showing compacts in the ad photos you posted. Did they make red Yanmars in this size?
   / Simple farm tractors are history #33
Like I mentioned the Yanmar YM4500 aka JD1250,
YM5000 is the JD1450 55Hp,
YM6000 is the JD1650,
And Yanmar made a YM7000, 78Hp machine too,
   / Simple farm tractors are history #34
Yanmar also made another series machine and had 4-cly turbo diesels with 110 to 120Hp tractors. Some were re-badged for Mitsubishi and Mahindra.
   / Simple farm tractors are history #35
Owned a Org. YM2000 since 2008 which is my FM. tractor. I rebuilt a 63 Ford for the size and Hp.. Org. Era. FEL.. 12V. and still using points!... My Yanmar was a imported rice patty tractor. Favorite!!
   / Simple farm tractors are history #36
   / Simple farm tractors are history #38
Ifbit
My 2002 only has 5 idiot lights, 3 gauges & 551 hrs. It'll last my lifetime. I do have a built-in theft prevention, if I don't hold the PTO lever back the ignition will not work, gotta replace that safety switch some day, but it's low on the important list.
works when holding the PTO lever back, it sounds like an adjustment of the safety switch or lever more than a faulty switch
   / Simple farm tractors are history #39
Todays farm tractors are packed with electronics and gadgets.
This is the dash of a Massey Ferguson today:
Every light on the dash, is a module to go bad, and a wire to break. I believe the original Massey 35 is still in production today - in Turkey. Africans love them
   / Simple farm tractors are history #40
You can still buy 35+ year old tractors that are simpler, but they are pretty wore out by now. You’d have to hope you can get parts for them.
We wore out my grandfather's Case SC four times already. My grandfather rebuilt it once, my father once, and I've done it twice. Just got through doing a valve job on it last Fall. Will be putting it back to work plowing vegetable plots if the snow ever melts away.
Dash consists of a manual choke, ignition switch, starter switch, headlight switch, and analog gauges for temperature, oil pressure, and charging system. Oh, and the gear shift emerges from the center.
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
1250 (A58374)
1250 (A58374)
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
2007 SUZUKI - MOTORCYCLE SV650/SV650S (A56859)
2007 SUZUKI -...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
