Simple cheap alarm design.
   / Simple cheap alarm design. #21
Soundguy.
For an entirely different project I need to replace mercury switches. I have rummaged around at my usualy haunts and don't really see an alternate. I was hoping for something electronic. The switches are used to keep the seat on the tractor level.
You have any other suggestions?
   / Simple cheap alarm design. #23
OK, I had another thought about this trailer alarm. Actually, two.
1. Can I and does it make sense to install a solar panel to keep the battery for the alarm system charged?
2. The trailer will have a electric brake. Can I tie the alarm in to energize the brakes if tripped?
If somone wants my stuff I'd like to make them work for it.
   / Simple cheap alarm design. #24
1. Sure...why not? One of those cheap solar battery maintainers mounted on the roof.
2. I'd do it. Just add a relay into the circuit that powers the noise maker. Then run power to the brakes. Should slow them down pretty good.
Actually if you have electric brakes you can use the brake battery to run the alarm system with a solar battery maintainer to assist in keeping it charged. You need to wire the NC contacts that power the alarm's audio alert across the breakaway switch so the brakes are applied when the alarm is tripped.
Whether you use the breakaway brake battery or a separate battery you need to "size" the solar charger to keep the battery up while it is constantly being drained by the relay coil current. To reduce the solar panel requirement you want to select a relay that a) can handle the current through its contacts to apply the brakes AND b) run the noise maker but have a low coil current at 12 VDC.
Here is a little help working it out:
1. multiply the coil current (probably rated in milliamps) times 24 hours to get milliamp hours yo will use per day.
2. You will need to put in about twice the amp hours into the battery as you want to take out (they aren't the best energy storage devices.)
3. A solar panel aimed south and tilted about 15 degrees lower toward the horizon than your latitude is a good year round average aiming. For a mobile installation where you may not want to keep fussing with the panel, just put it flat on top of the trailer and it will be fairly good but you'll need a larger panel.
4. Panels are often rated in Watts. To get amps at 12 volts, divide Watts by 12. This is how much the panel will put out in full sun, aimed properly, and not overheated. A fair rule of thumb is to assume your total daily output is about equivalent to 5 hours of bright sun. In a typical day with the panel aimed south 15 degrees below your latitude the total power collected is about the same as 5 hours of direct sun. The approximate range of latitude in the US (lower 48) is about 30 to 45 degrees. In winter the US gets less sun than summer so aiming the panel a little lower toward the horizon optimizes solar gain for the winter when you would otherwise get less.
5. OK, so 5 hours of sun has to provide at least twice the power used in 24 to have a decent chance of breaking even. (Remember the battery gives back about half of what you put in.)
First you need to know the relay coil current. Oh, by the way, so called 12 volt lead acid batteries are more typically used at 12.6 to 14.2 volts (12 volts is just a handy reference name) after you know how many amp hours (or milliamp hours) your rrelay uses in 24 hours you need the solar panel to make at least twice that in 5 hours.
For an illustrative example: If your relay pulled 100 milliamps that would be 2400 mAh or 2.4 amp hours. You need twice that (4.8 AH) in 5 hours so we divide 4.8 by 5 and get approximately 1 amp. We have to double that because of the way we get short changed by the battery. So the solar panel needs to supply 2 amps in brings sun to break even with your current draw averaged out over a 24 hour period. 2 amps is about a 25 to 30 Watt panel. Panels may run about $10 a Watt depending on your ability to ferret out a bargain.
You need to decide if you want to spend over $200 to avoid an extension cord to power a $7 Harbor Freight battery maintainer. The Radio Shack relay I used has a coil current of 130 milliamps or 0.13 amps which would require 30% more solar power than the example I gave above.
So you can see that finding a relay with very low coil current is a GOOD IDEA to save money on the rest of the design. For a solar powered system (the design I gave for a simple alarm was not optimized for solar power) you want to find a relay with very low coil current and use it to energize the heavier relay with the high current contacts.
Frequently the relays with really low coil current do not have high current contacts so you want to use two relays in the solar powered version of the alarm system. The coil of the low current relay is wired into the circuit in place of the original higher powered relay. the normally open (closed when energized) contacts of the low powered relay are used to apply power to the high powered relay. The contacts of the high powered relay switch the siren and brakes.
Digikey.com has several relays suitable for this application. You can find them with coil currents under 10 milliamp which would cut the solar panel requirement of the original relay I used (130 ma) to less than 10 ma with a corresponding reduction in solar power requirement to only 10% of the example I gave (100 ma coil.) Then a 2.5 to 3 watt panel would do the job.
There is some self discharge in batteries. They just lose energy over time. At some point if you reduced the power requirement of the alarm circuit low enough the self discharge of the battery, which is not being reduced, would become the major concern in the charging circuit.
Another issue: If you over size the solar panel too much then you will need a charge controller to avoid overcharging the battery which could shorten its life considerably.
After I had a trailer stolen I thought up lots of clever anti-theft devices (nail the barn door shut after the horse is gone!) Why not a large capsule of dayglow red paint in a pipe (think zip gun) with an explosive charge to propel it. The pipe is mounted facing forward so it would definitely hit the rear of the thief's vehicle in the lisc plate area and higher. If the bad guy(s) was (were) moving the trailer by hand it might paint whoever was near the coupler.
I thought of a time delay circuit powered by the brake controller batt (could use a separate batt) to set off all sort of pyrotechnics which should make the bad guys more than a little self conscious and apprehensive. There is no limit to the number or degree of aggressiveness of these sort of things. To be legal you need to stay non-lethal. One of my ideas was to use a magnet on the rim of a trailer wheel and a sense coil to compute speed. When the trailer exceeded 5-6 MPH (clearly the bad guys would be in the vehicle not outside exposed personally to my device) the equivalent of a couple electrically fired shotguns would be fired so as to take out the rear tires of the tow vehicle. This along with fluorescent paint fired onto the tow vehicle might make an impression on a witness.
Pat
   / Simple cheap alarm design. #26
Once again, Thanks for the feedback!
I do not expect battery/breakaway hardware with this trailer. It is only a 5 x10x6 V-nose single axle.
I got word that it came with brakes on the upgrade axle I wanted, a torsion flex rather than leaf spring.
My pop up camper had a simple setup, I expected that for this too.
I hit another larger shack in a local mall over the weekend. I did find the "drawers" that were talked about. They were a mixed mess with little inventory. The interest at the moment I was there was on someone walking out with two 150.00 radar detectors.
digikey.com site seems to be a bit complicated to use but will provide you with choices and one of the "filter factors" you can use in your search is that the product is IN STOCK.
The lower the coil current of the "small" relay that operates the larger relay which turns on the noisemaker the less solar panel you need and the smaller battery you can use so long as the battery has the storage to run the alarm noise maker you select.
Check the current requirements of the noisemaker. If the noisemaker uses less current than the small relay's contacts are rated for you only need the one small relay wired as in the circuit I posted.
The siren I have was purchased at the Shack decades ago. It has a built in relay to provide current to its motor directly from the battery and not through the alarm circuitry. The alarm circuit just provides current to trip that relay. If you can find a modern electronic siren (intended for alarm systems) with that sort of arrangement then the alarm circuit's relay can be one with a very low coil current and the total solar requirement will become quite small and pretty inexpensive.
Another option is to use NiCads or similar rechargeable battery technology instead of lead acid. Since you will not have a lead acid battery handy (such as for electric brakes.)
When you get serious and are ready to build the alarm, don't be bashful. Some of the electronic types hereabouts can help you out. I would be happy to help you select components or provide a schematic diagram to connect your components or...
Pat
   / Simple cheap alarm design. #28
I'm starting to visualize what I want and what makes sense for this alarm set up. By the way, I like your way of thinking. If it's mine and I don't plan on giving it away, lethal crosses my mind as well. With the info here and a friend I will test his limits on, I hope to be able to pull this together. If not I will be posting for help.
   / Simple cheap alarm design. #29
As much fun as the solar panel would be to work with, I found this at a local PEP Boys store. Can't beat the price and labor savings.
Battery Tender ョ Junior
12V 0.75A Battery Chargers
Our Part #: 021-0123 - The Best Way to Eliminate Sulfation is to Prevent it!
Battery Tender Junior offers 3-Step Charging with "Super Smart" technology. It will automatically charge any type 12 volt storage battery without ever over-charging. Including AGA, SLA, Flooded, Conventional Automotive and Motorcyle batteries. Brands such as Optima, Hawker, etc.
Great for any 12 volt battery. Leave it on any battery/vehicle while in storage and never have to worry about a dead or sulfated (ruined) battery ever again. Works on cars, motorcycles, ATV's, watercrafts, boats, and generators. Brochure Download (PDF Format)
12 Volt, 0.75 Amp, 5 Year Warranty
30 Day Satisfaction Return Policy
PRICE: Only $24.90
   / Simple cheap alarm design. #30
woodlandfarms said:
Soundguy.
Are you trying to refit merc switches with something else.. or put in new/more merc switches and can't find any?
soundguy
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
