Silly question, do I need to press in the clutch to go from forward to reverse?
   / Silly question, do I need to press in the clutch to go from forward to reverse? #1
vanguard
Raleigh, NC
2014 Kioti DK45SE
I have a DK45SE that I mostly use for mowing with a shuttle shift transmission. I was just watching a youtube video that explained that with a power shift transmission you don't need to press in the clutch to go from forward to reverse. I had been pressing it every time.
Do I need to?
   / Silly question, do I need to press in the clutch to go from forward to reverse? #2
According to Tractordata.com, that model is a synchronized shuttle-shift as opposed to hydraulic or power shuttle-shift, so you need to clutch to change directions. We have both types.
This may help at about 3:20 in: https://www.youtube.com/watch?v=xzdqA6NlXO0
   / Silly question, do I need to press in the clutch to go from forward to reverse? #3
YES. The shuttle shift is NOT power shuttle. If you try to move the shuttle lever without the clutch, you will quickly ruin something. On the DK shuttle shift, the clutch must be pressed to change direction, gears and range.
   / Silly question, do I need to press in the clutch to go from forward to reverse? #5
to add to the confusion I had a ck35 gear trans. Stepping on the clutch was just killing my knee. I learned I had a two stage clutch. I only had to lightly step down on the clutch pedal partially. Not all the way down.
What a difference that made.
   / Silly question, do I need to press in the clutch to go from forward to reverse? #6
Glad to hear you have it figured out.
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
2012 Cadillac SRX SUV (A55853)
2012 Cadillac SRX...
8ft Flatbed Truck Body with Axle (A55852)
8ft Flatbed Truck...
KUBOTA RCK48P-90T 48" MOWER DECK (A57192)
KUBOTA RCK48P-90T...
2019 Caterpillar 259D (A53317)
2019 Caterpillar...
2011 BMW X5 AWD SUV (A55853)
2011 BMW X5 AWD...
