Silly question, do I need to press in the clutch to go from forward to reverse?
   / Silly question, do I need to press in the clutch to go from forward to reverse? #1
vanguard
Bronze Member
Raleigh, NC
2014 Kioti DK45SE
I have a DK45SE that I mostly use for mowing with a shuttle shift transmission. I was just watching a youtube video that explained that with a power shift transmission you don't need to press in the clutch to go from forward to reverse. I had been pressing it every time.
Do I need to?
   / Silly question, do I need to press in the clutch to go from forward to reverse? #2
According to Tractordata.com, that model is a synchronized shuttle-shift as opposed to hydraulic or power shuttle-shift, so you need to clutch to change directions. We have both types.
This may help at about 3:20 in: https://www.youtube.com/watch?v=xzdqA6NlXO0
   / Silly question, do I need to press in the clutch to go from forward to reverse? #3
YES. The shuttle shift is NOT power shuttle. If you try to move the shuttle lever without the clutch, you will quickly ruin something. On the DK shuttle shift, the clutch must be pressed to change direction, gears and range.
   / Silly question, do I need to press in the clutch to go from forward to reverse? #5
to add to the confusion I had a ck35 gear trans. Stepping on the clutch was just killing my knee. I learned I had a two stage clutch. I only had to lightly step down on the clutch pedal partially. Not all the way down.
What a difference that made.
   / Silly question, do I need to press in the clutch to go from forward to reverse? #6
Glad to hear you have it figured out.
Bush Hog 2720 (A50120)
Coats CHD-9551 Tire Charger (A50121)
Coats CHD-9551...
2018 NPK GH-9 Excavator Hammer (A50774)
2018 NPK GH-9...
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
