Silinderrods bending ?
/ Silinderrods bending ? #2
If your FEL cyl's are bending, it is because someone is backdragging with the bucket with the cyl's extended. You can also bend your cyl rods by having too much hyd pressure. But you have to give us more into..... sorry....
My theory is......silindermountingpoint .....piston.......gland........rodmountingpoint...........If all 4 is evenspread from each other is will be strong ...........If silinder is overextended(piston and gland together then at its weakest and any missalignment with the welding on of the ends of the silinder will help with the bending .
/ Silinderrods bending ? #4
Could be. Hard to trouble shoot long distance with no pictures or much info.... Sorry..... :)
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
Case Titan 3530 (A63688)
Case Titan 3530...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
207923 (A63290)
207923 (A63290)
2020 TIGERCAT 234B LOG LOADER (A64276)
2020 TIGERCAT 234B...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
