Signal lights started flashing for no reason and won't stop flashing.
   / Signal lights started flashing for no reason and won't stop flashing. #1
wolfie1959
Northwest Connecticut
New Holland TC35D, Ford NAA and John Deere X530 garden tractor
My wife just came home and said " did you know the lights on your tractor are flashing?" I went out and looked and the signal was on. The switch is in the off position. So I turned it to the on position and it went off.. turned it back to and it stayed off for a few...looked again and it was flashing again.. nothing I do seems to stop it for long. Would it be a bad switch causing it? Something else? Another thing... Should they even work when the ignition switch is off? That seems like a bad idea to me.
Forgot to say it's a TC35D
   / Signal lights started flashing for no reason and won't stop flashing. #3
It's possible that the switch (a rotary, multi-position) has physically shifted one position 'over'.
OR that the external selector knob has done the same. I'd try this (the selector knob) first.
I guess that's possible but it just started doing it yesterday and no one ever touched the switch. It has been raining. I think it must be wet inside the switch.
   / Signal lights started flashing for no reason and won't stop flashing. #5
If you reckon that it's due to moisture then you could get a spray can of "contact cleaner" (basically compressed air & isopropyl alcohol). Aim it at the back of the muilti-position switch and then turn the switch' knob (gently) fully (to all positions) several times.
Do NOT use WD40... I know that the "WD" stands for water displacement however it's a petroleum based lubricant.
   / Signal lights started flashing for no reason and won't stop flashing. #6
The 4 way flashers are hot all the time, I have seen the relays hang and keep them on and the switches get moisture in them.
   / Signal lights started flashing for no reason and won't stop flashing. #7
I can guarantee that the flashing lights will work without a key in the switch. They are made that way on purpose for safety reasons.
I'm pretty sure the 4way flashers only work with the ignition on.. the signal lights are all the time. Makes no sense to me... I would think both would be the same. I don't like the idea of someone being able to turn them on and run the battery down when I'm not around.
The owners manual says that the turn signals are only supposed to work when the ignition switch is on. But mine have always worked when it's off.
   / Signal lights started flashing for no reason and won't stop flashing. #10
Typical. Water gets inside the switch. Take a hair drier to it from the top or replace it.
DYNAPAC CA30D SMOOTH DRUM ROLLER (A52707)
DYNAPAC CA30D...
UNUSED IRMC HIGH END ELECTRIC MASSAGE CHAIR (A57193)
UNUSED IRMC HIGH...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
UNUSED FUTURE 44" CAT305 EXCAVATOR RAKE (A57193)
UNUSED FUTURE 44"...
2017 Bobcat T770 Compact Track Loader (A55315)
2017 Bobcat T770...
2005 Freightliner M2 106 Dumpster Carrier Truck (A55852)
2005 Freightliner...
