Sight glass
   / Sight glass #1
redman1533
Massey ferseson 1533
My eyes are bad, I repaired leak in line, it's so hard to tell fluid in the glass, I may overfilled, or lost way more than I thought..is there any kind of a trick with a colored light? Permatran 3 is hard to tell, wish it had a dip stick.
   / Sight glass #3
Most all hydraulic fluids are hard to see but you can purchase oil dye to color it, I believe on Amascon or your local JD dealer. I say most, but not all. I use Chevron All Weather THF synthetic which comes pre dyed in orange of all things and it's easy to see in a sight glass or on a dipstick.
   / Sight glass #4
ON my MF GC1715 the background color od sight glass is silver, if fluid on in sight glass the portion of background covered takes on a greenish cast.... Otherwise hydraulic fluid die is going to help....
   / Sight glass #5
Mine also is silver; I had the same issue as the OP long ago and didn't realize that I was overfilling because the oil was just barely golden. You don't realize the difference till you've taken a good look at it both ways, and probably don't fully get it until it's too late.
The good thing is that overfilling is at worst going to make a mess when the fluid heats up, expands and then you go up a hill and it blebs out the filler tube...
   / Sight glass #6
I agree...had sight glass L2800HST seem I was always checking the level. 🙄
Tires 25x10-12 (A50322)
Tires 25x10-12...
Informational Lot - Financing (A52748)
Informational Lot...
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
