SIght Glass
   / SIght Glass #1
GregH
Bronze Member
I have a L4310 GST and the tranny sight glass is oozing fluid. Does anyone know how to tighten, replace, etc. this situation. Any help would be appreciated. You can push on the sight glass and it "gives" a little"
THanks in advance
Greg H
   / SIght Glass #2
Park the machine facing down hill or jack and support the back till you no longer see fluid in the gauge. Gently pry out with screwdriver or something suitable. Clean off the sealing surfaces, coat with black RTV/Permatex (why black? It dries quicker) and press back in, gently use a piece of wood or soft mallet if persuasion is required. Let dry and you should be on your way as long as the sight glass is'nt cracked.
   / SIght Glass
AS usual, someone steps up and comes thru in a pinch. Kubmech I appreciate the info. I was afraid it was somehow a major issue.
Thanks again
GregH
2012 Ram 1500 Quad Cab Pickup Truck (A53422)
2012 Ram 1500 Quad...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
