side to side leveling bush hog
   / side to side leveling bush hog #1
GodfreyDaniels
stanfield, nc
John Deere 4400
Just dumped my tiller for the season and attached the bush hog on my JD4400. Now the hog is significantly higher on the right side. I'm stumped.
   / side to side leveling bush hog #2
There is an adjustment bar attached to the lift arm on the right side most likely a screw type. You can adjust that side to be level with the left arm.
   / side to side leveling bush hog #3
Adjust your 3ph lift arms.
The bush hog was crooked laying on the ground when I attached it. Could it be that the hydraulic arm just picked it up from there? Perhaps I need to put it on level ground and reattach from level? It was level last season and I wonder why it isn't this season.
   / side to side leveling bush hog #5
It's probably not level because the 3pt arm that has the adjusting screw moved do you. Do what KYDan said and adjust the screw on the 3pt arm until it is level.
   / side to side leveling bush hog #6
Do you have a hydraulic side link?
The side links are the only thing that control if the attachment is level.
Unused 2025 Bale Spear Skid Steer Attachment (A51691)
Unused 2025 Bale...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
Can-Am BRP Side-by-Side (A51694)
Can-Am BRP...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
