Side Discharge Finish Mower?
/ Side Discharge Finish Mower? #1
TractorGuy
Elite Member
N. FL
John Deere 4410, John Deere 4120, Kubota LX3310 cab, John Deere F725 Front Mount Mower, Swisher 60" pull behind mower. John Deere 4310 CUT (sold), Ford New Holland 575E Cab Backhoe (sold).
Why would anyone make or want one?
My finish mower is rear discharge and I can't imagine why you would want a side discharge model.
/ Side Discharge Finish Mower? #2
For pull mowers, sure. Kind of a PITA for underbelly and front mowers, especially in dustier areas.
/ Side Discharge Finish Mower? #3
I've had 4 side discharge decks (one MMM and 3 RFM's) and 2 rear discharge (both RFM's). I prefer the latter, but could live with either.
The only bothersome thing I've had with the side discharge decks was not being able to mow in any direction. Mowing next to mulched areas had to be done in only one direction to prevent blowing clipping onto the mulch. The mowing pattern elsewhere needed to be planned so the clippings didn't end up getting piled up.
On the other hand, the side discharge aided in "raking" leaves in the Fall.
/ Side Discharge Finish Mower? #4
I have only used 3ph side discharge finish mower. Wondering if you can cut in reverse for any length of time with a rear discharge? Sometimes I have to back in and out of areas and the side discharge still throws out grass with no problem cutting in reverse.
I have no problem backing up with my rear discharge mower even in heavy grass. Sometimes it cuts even better since you run over it twice.
CAT 621B Final Drive (A68134)
CAT 621B Final...
Unused 2022 Loftness 14CFISV3 Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2022...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
1994 KENWORTH T600 (A67714)
1994 KENWORTH T600...
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
(4) 275 Gal Chemical Container (A64912)
(4) 275 Gal...
