Sickle Bar Sickle Mowers and Brush Hog
   / Sickle Mowers and Brush Hog #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
Did the Brush Hog just kind of take over the sickle mowers? I thought instead of using my neighbors 4ft brush hog I would get a 5ft for behind my tractor and then my wheels would at least be covered up. Then I was thinking how about an old sickle mower? But you can't find them used for a decent price and a new brush hog is less money almost. And I guess the brush hog would be easier to maintain.
But then again you would think if the brush hog is takin over you would be able to find the sickle mower used all over the place?
Just kind of confused here.
murph
   / Sickle Mowers and Brush Hog #2
Sickle bars are/used to be used for haying and the occasional cutting along roads/pond edges, etc. Brush hogs are for beating stuff into submission. You could possibly cut hay with a brush hog but you couldn't clear an area made a brush hog work with a sickle. BobG in VA
I was thinking for the open area in my back yard. It is just all grass with really nothing to worry about hitting. In fact I am sure it was hay at one time as it has a lot of clover in it. I just want to cut it down.
murph
   / Sickle Mowers and Brush Hog #4
I think the sickle mowers were originally for hay and have been replaced by lots of newer/faster implements. But I like to "bush hog" with my sickle mower. I have a 7 ft. model and that is 2 ft. more than my bush hog. Plus I have lots of rocks and it gets pretty exciting when I hit them with the bush hog, no big deal for the sickle mower. Check with any farmers in your area, they probably have them sitting behind the barn and might let you have it cheap, that is how I found mine.
   / Sickle Mowers and Brush Hog #5
I looked into a sickle mower before I got my Land Pride cutter.
Sickle mowers are more expensive ad require more maintenance then a cutter.
Also, when using one with a smaller tractor, one is putting a substantial amount of weight extended off to one side. Even with a counterweight, I was told the tractor is less stable.
Also, the only sickle bar mower I could find that would fit my 670 was a 5 footer. That wouldn't help me much on my embankments.
I looked at one to clear a heavily brushed area and embankments. I ended up using a 60" cutter for the brush and using a weed wacker on the embankments.
   / Sickle Mowers and Brush Hog #6
<font color="blue"> I would get a 5ft for behind my tractor and then my wheels would at least be covered up. </font>
A sickle is offset. It wouldn't cover your tracks. They are made so that you are not running over any of the grass that is being cut from the round you are currently cutting.
   / Sickle Mowers and Brush Hog #7
I think the other thing that drove sickle mowers out of favor is the effort to maintain them. When the sickle guard (the teeth) start wearing and the sickle wears, the thing won't cut worth a hoot. Especially some grasses are TOUGH to cut and a worn sickle mower just won't cut it. A bush hog, even with dull blades, will beat the stuff into submission.
Plus, hooking up a sickle mower is more complex than a bush hog. Some of them bolted to a cross bar and used the 3PH to raise/lower the cutting bar.
Having said that, if you want to mow over a ditch or next to a pond, a sickle mower is invaluable!
My 2 cents.
ron
</font><font color="blue" class="small">( <font color="blue"> I would get a 5ft for behind my tractor and then my wheels would at least be covered up. </font>
A sickle is offset. It wouldn't cover your tracks. They are made so that you are not running over any of the grass that is being cut from the round you are currently cutting. )</font>
Jerry,
I was thinking here about a 5 ft brush hog. I am using my neighbors 4ft right now and my wheels are wider which doesn't do a good job. Your right that is in part why I wouldn't mind a sickle because it is offset. Even with a 5ft brush hog your wheels will knock the grass down and then not mow so you end up coming back over it a few days later.
murph
   / Sickle Mowers and Brush Hog #9
Sorry, I guess that I got your sentences out of order.
   / Sickle Mowers and Brush Hog #10
Remember tho the sickle mower will cut the grass and leave it just lay there whereas the hog will chew it up into smaller pieces. You are also correct, trying to find a used sickle mowere is next to impossible, unless it is junk.
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
