Mowing Sickle mower
   / Sickle mower #11
The CCM Super 65 is designed for compact tractors. $995
   / Sickle mower #12
What's the PTO hp recommendation for this model? Thanks.
   / Sickle mower #13
Minimum PTO HP needed for the Super 65 is 12 HP.
   / Sickle mower #14
CCI,
Do they make a 7 footer?
How much are new blades?
Are they sectioned?
How hard are they to get(imported I guess)?
Will they cut through "bunch grass" around a tank?
   / Sickle mower #15
These Sickle bar mowers are made for compact tractors. The main duty is trimming around and mowing ditch banks. Sickle bar mowers are not intended to be used as bush hogs but can handle 1/2" stuff on a limited basis. We do not make a 7' because many of the CUT's could not accommodate that size.
   / Sickle mower #16
CCI, when the sickle mower is mounted, does the cutting edge start at the outside edge of the wheel, or is it inbound of that. I'm trying to figure how far it will actually cut beyond the outside edge of the rear tire on a BX 2200.
Also, approximately what angle can the bar be used? If you are riding beside the ditch (or in my case the pond) will the cutter angle downward? If yes, do you know the angle?
Thanks in advance for your answers.
Bob
   / Sickle mower #17
Glenn9643, I saw an ad in the "wanted" column in the LA Market bulletin. Didn't realize it was yours. When I read it, I said "Good Luck, I've been trying to find one myself". Guess the jokes on me. I didn't think anyone responded to the "wanted" ads. If you got a NH 451 for $300, you got a helluva deal. Did he have another one by chance? /forums/images/graemlins/ooo.gif
   / Sickle mower #18
The Super 65 will start cutting at the outside of the rear tire. It will mow 70 degree vertical and 20 degree below horizontal. The cutterbar cuts 5'5". This mower is designed for compact tractors.
   / Sickle mower #19
DK_Farms,
The owner wasn't a dealer and had nothing else to sell that I'm aware of. I had two or three other calls of interest other than the one I bought. While I was driving south to get the mower I had a call from someone in N Louisiana with a IH 1300 for $300 and another guy (I think near Jonesville) with a JD 350. If you're looking I would recommend the "wanted" ad because it seems like by the time you call after seeing the ad in the bulletin someone else has bought it. If it's a deal the first caller is going to buy it! I've noticed the the MS market bulletin has listed several in the past few months and would recommend posting a wanted ad there if you're willing to drive a little.
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2020 DRAGON ESP...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
2019 FREIGHTLINER SD122 DAY CAB (A57880)
2019 FREIGHTLINER...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2022 Ram 2500 (A55973)
