Sickle Bar Sickle Mower vs Rotary
   / Sickle Mower vs Rotary #11
Neil L said:
Very near Polo Fields out US60 near Shelby County
I'm out that way quite a bit. I make a trip every few weeks to Cottrells Massey Ferguson (Simpsonville) and on to Shelby Supply (Deere dealer). Also looking at 18 acres (for investment purposes) in Eastwood. Pretty country without a doubt!
Neo, I think you simply let it ride ground as lifting the 3PH picks the whole thing up. To get down the steep banks, I think you will need to use a belt driven unit. I have been led to understand that 20 degrees is all you can get with a pitman drive. Check around as I can be mistaken.
Best, Neil
Farmswith,
we are on 5 acres 28yr in the suburbs of East Wood. Think invsestment potential bright.
TSC in Shelbyville is run by Irv who was "THE MAN" when they were downtown.
Have you found H&H Farms used equipment located behind the Chinese resturant across from Thorntons, top of hill past Jacobi in Shelbyville?
   / Sickle Mower vs Rotary #14
Neil L said:
Farmswith,
Irv runs that store to his own tune. It's what ALL TSC stores should pattern themselves after.
I also used to mow a place for a friend on Fisherville-Eastwood Road. Just before it crosses under I-64.
Yeah, I ran onto H&H last trip down that way. They have some of the "inventory" from the old "Climax Farm Equipment" that used to be where the new Lowes is at now. Sounds like we've probably crossed paths a time or two.......
   / Sickle Mower vs Rotary #15
Neil - I bush-hogged approx. 8 acres today at my BIL's farm. He usually cut it with a sickle bar mower and let it lay on the ground. He's disabled now and it hasn't been cut for two years, so I cut it with my Kubota/Bush Hog Squealer.
It doesn't appear that the hay laying on the ground was a problem, infact it appeared to act as a fertilizer as the field was lush with high grass and weeds. The Rotary knocked it down, but not nearly as nice looking a job as with the sickle bar. Usually use the Rotary on brush, weeds, etc. not the best for hay. If you want looks, go with the sickle bar. Have fun, but slow and easy - be safe :)
penokee
Penokee, Thanks for the info on field condition after hay laying, and the observation of rotting. Probably good housing for wildlife for a while too.
Best, Neil
   / Sickle Mower vs Rotary #17
My neighbor mows his field once a year when it gets tall and lets it lay. The next year it's as tall and green as the year before. That is a lot of nitrogen you're laying down. I think he mows late June here in PA, so that gives him about 8-9 months for it to compost and feed the soil before things start popping up in March.
What brand and model is your mower, and if you don't mind my asking, how much did you pay? I looked for years to find a non-pitman SBM. Any cruddy SBM in semi-useable condition at auctions in my area were going for a fortune ($800 to $1300 for what looked like junk). I finally found a NH 456(?) in good condition nearby for $1000. It was regularly used and well maintained, and he threw in what extra blades and other hardware he had left.
I love mine and use it for spanning drainage ditches, keeping the fence row clear, knocking down weeds in the pasture when they get too high and mowing some swampy sections of lawn that won't tolerate the 3pt finish mower.
Mine will mow in any "angle of attack" including it's stowed position. I'm eventually going to drop it with the local Amish custom welder, who does great work for cheap, and have him fit it with a hydraulic cylinder to raise and lower it to any position. (He's also a sickle bar expert and carries all the parts I never thought I could even get anymore.) That will make maintaining a half mile long driveway through overhanging sticker bushes more like revenge than work!
If your cutting bar extends beyond the shoe at the end of the bar as it goes back n' forth, believe me, you don't want to hammer into any big rocks hidden in the weeds. I finally moved my bar to the maximum outward stroke position and cut it flush with the edge of the shoe so I can no longer whack any hidden objects.
Roy
Roy, Glad to share. IH model 1300 Balanced Head Mower 7' in almost new condition. Tried to do better but still think I got a very good machine at a fair price $1200.00 plus 2 spare blades, one with new cutters. Did a partial take down, wire brushed some paint nicks, knocked out a back-up dent out of belt cover taped the decals and gave it a coat of IH red.
Anyone have an Idea where to locate decals for used equipment?
I have really only run mine for about 30 min. and am very happy I chose to get one. Tried it out on neighbors property which consister of some thick grass and dome areas of large weeds, no problems. I got interested because of the comments here on TBN.
This weekend I am hauling To WV and intend to give it a real workout. I think that as well as your briers it will cut 3/4 saplings as well, Maybe wrong on this but will Know soon.
Thanks for the blade length tip, will check and correct if need be.
Best, Neil
Best, Neil
   / Sickle Mower vs Rotary #20
Neil L said:
...Did a partial take down, wire brushed some paint nicks, knocked out a back-up dent out of belt cover taped the decals and gave it a coat of IH red.
... I think that as well as your briers it will cut 3/4 saplings as well, Maybe wrong on this but will Know soon.
You sound like me. I tore the bar down to pretty much individual pieces, replaced old stuff, wirebrushed and repainted. The frame is another story. It is too much to clean up by hand, too many nooks and crannies, so I'm presently awaiting delivery of a sandblasting kit.
Good luck finding decals! I've given up on that. Went to a NH dealer and told them I was restoring an old SBM and they were really cool. Decals were out of the question, so I asked them if they could find any literature showing the model number and logo. A few guys were simultaneously looking for stuff for me but they all came up empty. If I could at least get decent images, I have a waterproof inkjet where I could create my own on decal stock. If you find a source for old farm equipment decals, please PM me.
I believe mine is rated to 1" and I think I've taken down larger than that! That's mine though.. I couldn't find a picture of what your model looks like. I found an IH Fast Hitch Model 100 and it doesn't look like I'd attack anything too big with that one.
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2003 Pierce Spartan Pumper Fire Truck (A55852)
2003 Pierce...
27031 (A55852)
27031 (A55852)
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
40 CONTAINER W/CONTENTS (A55745)
40 CONTAINER...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
