Sickle mower for fine thick grass??
   / Sickle mower for fine thick grass??
My guards are also all smooth,, actually rounded over:laughing:. How do the ledger plates fit on? I guess you have to order special guards for ledger plates. I have heard of them but never used them or seen one. Where would I order them?.. thanks
We sell them and use them. My Operations manager has ran a double action for years and says he had rather run it that his 8 ft disc mower. Ours are the 394-7 Superior for $3695 with hydraulic lift. Ken Sweet
Thanks Ken. I'll look at your site and those mowers!
   / Sickle mower for fine thick grass?? #14
I think some of my problems is the rock guards are a little worn. Those drum mowers look trick. I was also looking at the "double action" type sickle mowers made by Befco and another company. I was wondering if the double action type sickle is better for thick grass?? Does anyone here own a double action type sickle mower? thanks for the previous replies!
The double action sicklebar mowers do not like fire ants, sticks & rocks. They must be used in pristine conditions. We have sold the double action G&S Superior mowers since the 1980's. They are higher maintenance than a drum mower. You can do $$$ hundreds damage in a second if you catch a rock or stick in the guards. The repairs on the double action mowers are time consuming & expensive. With the drum mower the blades are $1.25, only 6 and you can replace them all in 2 minutes. The drum mower will mow any crop as fast as you can ride.
   / Sickle mower for fine thick grass?? #15
All true, but you can't run a drum mower down into the water to trim a pond.
   / Sickle mower for fine thick grass?? #16
If you want to run one in the water, a single action sicklebar mower like a NH 451 would be better and more durable.
   / Sickle mower for fine thick grass?? #17
Ive got drum mowers and disc and a double action sickle mower. I wish drum mowers were wider more than 7 ft. Disc mowers are expensive when you chew rocks and chunks. Double action sickle cuts good but can be expensive and time consuming to repair.
   / Sickle mower for fine thick grass?? #18
Most drum mowers above 7' are usually in a pull-type configuration.
   / Sickle mower for fine thick grass?? #20
Look on S.I. Distributing website for SCH System. I have them, best money I ever spent on hay equipment. Also check your sickle register no matter how good your sections, guards, and hold downs are if the register is not right it will not cut good.
JOHN DEERE Z920M LOT NUMBER 222 (A53084)
JOHN DEERE Z920M...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
40ft Sea Container (A52384)
40ft Sea Container...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2019 FREIGHTLINER...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
