Sickle bars always noisy when off the ground?????
   / Sickle bars always noisy when off the ground????? #1
kentuckydiesel
I've got a JD model 39 sickle bar mower that I picked up used and needing a few things. It's a 3pt mount. If I have it running and raise the bar off the ground it gets really noisy and I fear I will break the pitman. Is this normal? Do I have to worry about the pitman breaking under these conditions? I think the noise is from the bar flexing downward while in the air and may be binding slightly. Thanks, Phillip
   / Sickle bars always noisy when off the ground????? #2
I recall there is a lot more "chatter" when the bar is raised, but slowing the rpm down will calm that noise down. I don't think there is a danger of ruining or breaking the pitman arm, if it is greased properly and in good repair. Certainly more load on the arm when cutting than when running free. But i can understand your cause for concern.
I'd just lower the rpm a bit.
   / Sickle bars always noisy when off the ground????? #3
<font color="blue"> </font> I think the noise is from the bar flexing downward while in the air and may be binding slightly. <font color="blue"> </font>
There is a adjustment on those mowers to cause the tip of the bar to come up quicker when the 3 point is raised. You may want to set the upper limit on the 3 point lift control lever on the tractor (the pto may be getting in a bind on the extreme up position)--Ken Sweet
Sweet Farm Equipment LLC *2 Stores in Central Ky to Serve Our Customers Needs*
   / Sickle bars always noisy when off the ground????? #4
I agree the noise likely comes from the bar flex putting pressure on the throat plates/guards. However, make sure the pitman is the spec item - improper length could affect timing/position of cutter sections in relation to complete stroke through the guards....a long shot, but worth checking. I don't remember if the manuals show the measurement or not.
It's been 40 years since I ran the sickle bar mower on my Farmall M!
Dave in VA
Raised on an IN farm
UNUSED AGT MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED AGT MINI...
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
Test Button (A47384)
2013 Ford F-150 (A50397)
2013 Ford F-150...
2000 PETERBILT 379 TANDEM AXLE SLEEPER (A52141)
2000 PETERBILT 379...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
