super55
Platinum Member
- Joined
- Jan 27, 2012
- Messages
- 920
- Location
- Great North of Michigan
- Tractor
- Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had),
Whats your thoughts on sickle mowers. My experience is only based on about 20 feet of mowing before I had a catastrophic failure of an old MF 41 3 point sickle mower.
I obviously bought the thing used but it was in great shape for it age other than the drive belt. Put a new belt on lubed, up all the joints, ran a rasp file on the knives to give it a new edge and checked to make sure none of the knives were binding or had excessive clearance. Everything was good to go so I thought but boy was I in for a surprise.
So I went to go start my perimeter swipe. Mowing a winter wheat/fescue type field. I decide to try and start slow since this is the trial run. End up getting hay bound up between the bars and hear the belt starting to squeal. Shut her down clean out the bar and decide that maybe I was going to slow and instead of laying the hay down I was dropping it down on the bar and it was clogging the sickle. Attempt #2 I decide to kick the speed up just a tad. Make it about another 10 feet and then notice the PTO is spinning but the bar is not cycling. After inspection, I noticed I blew out the cast housing that has a connecting rod to the sickle bar. Tried to weld it but being cast metal the weld didn't hold and immediately broke again which I figured it most likely wouldn't.
Needless to say my experience with the sickle type mower wasn't a pleasant one. I know a lot of people use them on here and have very good success with them but my experience was less than desirable. Fortunately I didn't spend a lot of money on it. I've decided to start putting money away for a small drum mower next year. A drum mower from what I seen on youtube vids seems to be a lot more forgiving and a lot less maintenance than a sickle.
