Sickle Bar Mower
   / Sickle Bar Mower #21
This is worth repeating, over and over. Short of mowing over ditches or creek banks, I can’t think of one reason to choose a sickle bar mower over a drum mower. I really can’t even believe there’s enough market that they still make them new.
I cant REALLY argue that, having never used a drum mower. But I nave used a bush hog, don't like the steaming piles it leaves behind in some cases (pasture grass).
There can be improvements. Hydraulics for up/down. Some arrangement to move in/out would be an improvement then you could cut under a fenceline. It's kind of a PITN being hard-mounted to the right rear. Like the sickle mower was forgotten before the hydraulics era. Currently able to cut under tree branches & bushes that the tractor can't drive under. Sometimes its useful to rake up the cutting and burn them (if seedy).
   / Sickle Bar Mower #22
A drum mower is another option for mowing hay. Very similar to a disc mower, but made for lesser HP tractors. A brushhog isn't made for cutting hay. For what you listed, a drum mower would do everything a sickle bar will do, except faster and cleaner. Of course, if the primary use isn’t cutting hay, then buying a used sickle bar is the smart choice. But as a primary means of cutting hay, and for equal money, the drum mower wins hands down.
   / Sickle Bar Mower #23
<snip>
I mostly use mine in the vertical position...usually once a year to trim the sides of the road...I bought a cylinder to control the bar but have not had time to fabricate the mounting brackets etc...
That is what I'm wanting a sickle bar mower for - advanced hedge trimming.
This is worth repeating, over and over. Short of mowing over ditches or creek banks, I can稚 think of one reason to choose a sickle bar mower over a drum mower. I really can稚 even believe there痴 enough market that they still make them new.<snip>
Also ditches beside the road.
   / Sickle Bar Mower #24
If that’s the case, how about used? The very best used cutters around here won’t run you more than $500.
   / Sickle Bar Mower #26
We had a lot of drainage ditches to keep tidy, so Dad's AC-B with the mid-mount was just the ticket, made it easier to keep an eye on the cutter to see what was happening.
   / Sickle Bar Mower #27
We currently stock the new Tar River 5.5 and 6 Ft drum mowers with Hydraulic lift or manual fold around on the cutter bar. Ken Sweet
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
(INOP) WOODS 6' ROTARY MOWER (A52708)
(INOP) WOODS 6'...
2008 Dodge Ram 1500 Pickup Truck (A55973)
2008 Dodge Ram...
2012 MACK GU713 (A58214)
2012 MACK GU713...
9ft Military Cargo Trailer  Heavy-Duty, Off-Road Ready (A59225)
9ft Military Cargo...
