Sickle bar for DK-40?
/ Sickle bar for DK-40? #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Anyone use a sickle bar on a DK-40 or similar Kioti model? Where might I find a good used one? Any particular brand loyalty? Would like to run a PTO driven one if possible. Don't really want to go with a mid-mount- too much hassle, I think- plus I've got a subframe mount hoe which might be a problem, or not, but i just would rather drive one off the back end.
/ Sickle bar for DK-40? #2
I have used New Holland 451 for years. JD 450 and International Harvestor are good also
/ Sickle bar for DK-40? #4
Check and see what others in your area use and whst dealer is available. Aftermarket guards sections are good but go back to dealer for bearings. Also dont use rivets on sectios use bolts you will lose a lot less sections. You may have to go to higher clearance hold downs
