Sick of Surge Brakes
   / Sick of Surge Brakes #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Again, out of the clear blue, a wheel locked up without warning. Another tire ruined and a PITA. After 15 years of dealing with this random failure and ruined tires and service bills, I'd like to change the whole thing over to disc brakes. What do you all think? Is it possible? I can ask some trailer dealers when I get to it. Heck, buying tires and the concomitant grief is more vexing than a whole new system....that is, something that is dependable.:mad::mad::mad:
   / Sick of Surge Brakes #2
Even disc brakes can cause problems on a trailer.
I suggest that you talk to a couple trailer manufacturers or repair shops and get a price on new axles with good old electric drum brakes. Then put a controller on your tow vehicle. You're done, for thousands of miles.
   / Sick of Surge Brakes #3
Trailerpartssuperstore.com has everything & more.
   / Sick of Surge Brakes #4
I have converted 2 of my 3 trailers to disc. They are awesome.
Chris
   / Sick of Surge Brakes #5
I have a couple of trailers with electric brakes ........... love 'em! Gotta keep the contacts clean, but then that's the case with all trailer plugs. One of the trailers is a 7000# 4 horse gooseneck, it'll push the truck around a bit when it's loaded and the brakes don't work.
   / Sick of Surge Brakes #6
I recently added drum brakes to a bare bones cargo trailer, new hubs & drums.
Hardest part was crawling around underneath doing the wiring.
IIRC, less than $300.
Thanks again, TBN'ers. This has come up before and your were helpful. This is a dual axle equipment (skidloader) hauler, and really sits low, as commented. But I've been under there so many times, I'm getting comfortable with that. As Bigfoot noted, what could be a problem with disc brakes as a replacement? I guess I should have titled this thread as "sick of drum brakes".
   / Sick of Surge Brakes #8
I converted my boat trailers surge brakes to electric. It was an easy conversion. I was even able to use the stock drum. Just had to buy the plate with the electric pads and weld up the coupler so it doesn't pivot. I would imagine the conversion to disk would be simple as well but more expensive.
As far as the wiring, just use you skid steer and lift up one side and run the wiring while standing.
Thanks, Je Je. I just ordered (yesterday) all the parts to convert to electric. The Redi-Haul trailer people are real helpful on the phone and quite patient with me as a DIY'er. It's gonna cost about $300 bucks. Your input gives me a good feeling about this.
Cheer,
Mike
   / Sick of Surge Brakes #10
Cheer,
Mike
$300? Must be stepping to the plate and installing the disc. Either way, packing the wheel bearings is the worse part of the job. You will like the electric over the surge and plus they will work while backing down the ramp.
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2015 KUBOTA M9960 LOT IDENTIFIER 121 (A53084)
2015 KUBOTA M9960...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2014 Vermeer SC802 Towable Stump Cutter (A51691)
2014 Vermeer SC802...
BOX OF SCHUMACKER 3A BATTERY CHARGERS (A51248)
BOX OF SCHUMACKER...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
