Shuttle Valve For Lawn Sprinkler System?
   / Shuttle Valve For Lawn Sprinkler System? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Here's the issue: My Sister in Law's automatic sprinkler system has one zone with too many sprinkler heads to operate at one time so it has two ball valves that have to be manually switched to do half at a time. The ideal solution, of course, would be to install another solenoid valve but the distance is quite a ways from the controller to run the control wire.
The shuttle valve shown above is what could be used except it it designed to COMBINE two inputs into one output. I need a solution that does just the opposite. It would need to direct the pump flow to one side of the tee for watering half of the zone and then to the other side to water the rest of the zone. It would automatically switch to the other outlet of the tee when the upstream solenoid switches off and relieves pressure. Then the rest of the sprinklers on that zone would be watered and the process repeated for the next watering cycle.
I know it's a long shot but wondering if such a valve exists or whether something similar could be cobbled to achieve the desired results. TIA.
   / Shuttle Valve For Lawn Sprinkler System? #2
The only thing that I could think of to do would be to put a timer at the current valve location.
Remove the valve from it's current location.
Remove both ball valves.
Put in a timer with a on-off-on switch to run off of the original valve's wiring.
Put the original electric valve in place of one of the ball valves.
Put in a new electric valve to where the other ball valve was.
Have the timer feed both valves.
When power is applied to the circuit, the timer applies current to one valve. When it times out, it sends power to the other valve.
So say you want water to run for 20 minutes on each leg. Set sprinkler timer for that zone for 40 minutes, set timer for 20 minutes. It'll switch half way through the cycle.
Personally, I'd just run another control wire and install a 2nd valve.
"Personally, I'd just run another control wire and install a 2nd valve"
Yes, that would be the best long term solution.
Using a timer to do the switching electrically is a good idea except the existing valve with its 24VAC is about 100 feet from the tee and the two ball valves so would require trenching in a cable. Also, there are switches on the market designed to control two or more valves in a valve box when the wire to one or more of them has been broken somewhere.
I've sometimes wondered why a low voltage cable couldn't be threaded inside an existing water pipe. I know it sounds silly but if there was a way of creating a leak proof entry and exit for the wire.........
They need to invent PVC sprinkler pipe with embedded control wires with plug-ins for signal entry and exit points.
Sorry, us old retired folks have nothing better to think about. :)
   / Shuttle Valve For Lawn Sprinkler System? #4
No. You need a 24V timer to operate the 24 volt valves. That way you could just use the existing wire.
And don't laugh. When you mentioned running wire, about the 1st thing I thought of was, man, if they could only run the wire inside the pipe and make it exit leakproof. 🤣
   / Shuttle Valve For Lawn Sprinkler System? #5
I think it would be called a time-delay relay. When power is applied, it starts the delay. At the set time, it would open or close, and you could use that function to apply power to the 2nd valve.
Anyhow, it's possible. I'm sure someone else will have a better idea.
Not sure what you mean. Would still have to run a cable the 100 feet, no?
Great minds think alike, eh?
Why couldn't a person drill a small hole near each end of the pipe and then pull the cable. Glue one of these saddle fittings over each hole and install a regular 1/2" electrical compression fitting to seal around the wire?
Would be easy enough to pull the wire especially in 1" PVC pipe if no elbows involved. Even then it wouldn't be difficult to install another pair of saddle fittings if necessary to "bypass" the fitting.
I've used the PVC snap on saddle valves and they do work well.
I know, water and electricity don't mix, but in reality they would be isolated and it's only 24VAC.
Somebody will say, "not to code", and I get that.
   / Shuttle Valve For Lawn Sprinkler System? #8
Ahh... your electric valve is 100' from your ball valves? I didn't think of that. Crud.
Well. I do have an older version of one of these that I use to water my yard, garden and flower beds. Up to 4 zones. It's battery operated (2 AA cells). You could put it at the TEE where your two lines split and set the clock. It would work just fine. You'd have to make a couple adapters.
This is a 2 zone system. $40 solution.
Mine has been in service for about 10 years. The batteries last more than a full season. The clock is very accurate. Put it in right at your tee and you'd be good to go.
That's excellent! I've seen them online but only in single station. Thanks!
   / Shuttle Valve For Lawn Sprinkler System? #10
I like that doubler. Never seen that before. Could have used it in the past.
2003 Volvo S60 Sedan (A50860)
2003 Volvo S60...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2022 Club Car...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2019 Komatsu PC490 Hydraulic Excavator (A49461)
2019 Komatsu PC490...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
