Shuttle transmission
/ Shuttle transmission #1
Anonymous Poster
Epic Contributor
I am still collecting information re. the 3054 Kioti. I have not found any information explaining the shuttle transmission. I understand that it is excellent when compared to the conventional transmission offered by Kubota on its L3000. Can someone explain how it works? I will really appreciate any help.
/ Shuttle transmission #2
I'm not mechanical enough to explain it to you, but here's a thread that will do a pretty good job for you. <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=genoperating&Number=181985&page=&view=&sb=&o=&vc=1>Shuttle Shift</A>
/ Shuttle transmission #3
Basically it's 2 transmissions in one. The trans that governs the speed and one that only does forward/reverse. The Speed trans is synchro'd meaning you can shift it like a manual trans car, clutch and go. The shuttle(on this particular model) is unsynchro'd meaning you must come to a stop(or be very good at shifting) to go between forward and reverse. This gives you 8speeds forward (4 in hi range-4 in low range) and 8speeds in reverse(same). Reverse is slightly slower than forward.
The trans is a good compromise between a hydro and a conventional gear trans.
BTI
The shuttle saves you from having to shift through the gearbox to get to reverse. You simply shift one direction for forward and the other for reverse. This is especially helpful when using a loader or even mowing, since you're not creeping backward in reverse. The rearward speed at approximately the same as the forward speed greatly speeds your work, especially with the loader. It really helps if the shuttle is synchronized so you don't have to come to a complete stop to shift. However, if money is important the 3054 will work fine.
2019 Autocar ACX Xpeditor T/A Heil 31Yd Side Loader Garbage Truck (A61568)
2019 Autocar ACX...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2013 Tahoe Q4 Boat with 2013Tracker 18ft S/A Boat Trailer (A61569)
2013 Tahoe Q4 Boat...
2006 Link Belt HTC-8675 75 Ton Hydraulic Truck Crane (A60352)
2006 Link Belt...
Generac Guardian Ultra Source 15,000W Portable Gasoline Generator (A61567)
Generac Guardian...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63118)
2023 Kubota...
