Shuttle shift usage Kubota M7060
/ Shuttle shift usage Kubota M7060 #61
Still confusing. So to shift I just shift and forget about the clutch?
A GST operates just like an automatic, no clutch needed. You shift gears & throw the shuttle lever from forward to reverse without bever touching the clutch.
In the couple hours I ran a GST I never got the hang of the shuttle timing. I used the clutch helping cleanup & pile limbs. But another few hours I'd have gotten it down.
There is a second or delay on some shifts which is annoying at times, at least on the 30 series I ran. A little delay on the shuttle lever, but it was consistent on the shuttle unlike the gear shift lever.
/ Shuttle shift usage Kubota M7060 #63
Neil at Messick's has done a video that demos a GST unit and explains its advantages in certain applications.
Kubota L4060 with Glide Shift Transmission(GST). Demo and Functionality. - YouTube
OK, got it and great video.
A GST is just like a hydraulic shuttle shift but with one difference. Instead of "gears", it has forward and reverse "ranges" (same thing) and you can change gears/ranges while moving and without clutching. That's all and that simple and I no longer fear that transmission. Watch the video.
/ Shuttle shift usage Kubota M7060 #64
So it's similiar to JDs old power shift trans. Still need the clutch for "inching".
/ Shuttle shift usage Kubota M7060 #65
I test drove a GST setup when shopping for my Grand L years ago. Ultimately went with HST but the GST was a nice setup. I would have had no problems using it but indeed found the HST easier for loader work. It did seem like a fairly complex system and it made me wonder how "idiot-proof" it would be as a rental unit, for example, but I guess there have been lots of L35's and L39's that held up well in such use.
/ Shuttle shift usage Kubota M7060 #66
I don't know about rentals, but my L4200 GST has held up well going on 21 years now. :thumbsup:
Although I will be giving it up this Spring for a new L5060 GST. ;)
/ Shuttle shift usage Kubota M7060 #67
More or less. PowerShift is a 2 clutch system that shifts REALLY fast under load. GST has half the gears, 1 clutch (I think) & takes a second or so to shift. Different classes of machines as the JDs I'm familiar with were 2-5 times the machine a CUT us, but has the corresponding price.
GST is the Cadillac of gear transmissions on CUTs & SCUTs. Personally I'm not familiar with JDs current CUT transmission offerings, other than a nice HST. That HST was nice, smoother than Kubota & had a nice sensitivity knob rather than 1 button that also ran a million different other functions. No 2 speed shift under power HST+ equivilant on JD though, otherwise I'd have looked at JD harder for my L4060hstc.
/ Shuttle shift usage Kubota M7060 #68
Around here, used GST's will sell for less than other transmissions. I now will say that's because of user ignorance and that might be an opportunity for me to trade up and get something I can use and at a great price.
/ Shuttle shift usage Kubota M7060 #69
Not trying to talk you into spending money but,,, if you do please start a thred describing how the GST works.... :)
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2016 HAMM H11IXP PADFOOT ROLLER (A62129)
2016 HAMM H11IXP...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
Honda 300 Four Trax (A61166)
Honda 300 Four...
