Shuttle shift slips out of gears
   / Shuttle shift slips out of gears #11
well ive replaced switch for f/r, the turtle /rabbit switch, the module and adjusted cable from pedal to solenoid and still having intermittent problem. suggestions/solutions....please
   / Shuttle shift slips out of gears #12
So my 2120 New Holland had been spilling out of gear also , after 10 minutes driving it , it would just go into nuertral by itself. New holland Brookville said it was fine after a few hundred dollars in shop bill. No Change. Greensburg took it in and Actually tested everything ! The problem is a FNR Switch they can get a short in them , they charged $75 dollars for the part , tractor runs now like never before !
   / Shuttle shift slips out of gears #13
Again I had same problem , it was the FNR Module replaced module and harness, No Problems fixed !
TANK MANIFOLD (A58214)
Eagle Weathervane (A55853)
Eagle Weathervane...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
skeleton / rock bucket (A56857)
skeleton / rock...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
