Shuttle Shift or Hydrostatic.....
   / Shuttle Shift or Hydrostatic..... #51
This may help explain why Hydro can be so precise ...
On the gear, in addition to how you shift from forward to reverse, the speed is controlled by pressing the accelerator pedal (I won't call it a "gas" pedal since the tractor is diesel) and shifting is done with your hand.
With any of the HST tractors I have used, speed and direction is determined by pressing the pedal(s) in the direction you wish to go since the engine speed is constant and set by a throttle. Your hands are free to drive and operate the loader or other equipment levers.
I have used plain gear, shuttle and HST - I'll take the HST for all-purpose tractor work any day.
I don't know how common it is on other brands but the RK55 also has an auto-throttle switch which controls the engine RPM in proportion to how hard the hydro pedal is pushed. It's pretty handy when you are doing a lot of stop and go or don't need much speed on the hydraulics.
Gotta learn somehow. And how about, it’s never too late to start.
   / Shuttle Shift or Hydrostatic..... #53
When you get your manual, check your manual. Kubota manual states when shifting from L-M-H the tractor needs to be completely stopped. The Hi-Low can be shifted while moving (this is Kubota HST+ transmission).
On the RK55 the HI-Medium-Low Range is a gear shift (real gears) and the tractor needs to be stopped to shift between them. Don't let this confuse you on a hydro. Once you have selected the range you want you use the pedals to move the tractor. Forward/Reverse and control the travel speed by how far you press the pedal. Pressing the pedal more will give more ground speed for the given range you have selected and rpm on the engine. Medium range is the most useful range for just about everything. Hi range is good for smooth road travel. Low range is used when you really want to get maximum push force. I can spin all 4 tires on sod in low range with the differential locked. That is a lot of push force and I bent my bucket in the middle messing around with a stump doing that so be careful!
The response switch for the hydro controls how fast the transmission reacts to the pedal being pushed and released, it is a rocker switch and can be switched at any time.
   / Shuttle Shift or Hydrostatic..... #54
Ain't that the truth, my father in law never used or owned a tractor until his mid 60s when he retired and bought two farms. He had to learn on his own as he wouldn't listen to me. It cost him $$$$$$$$$$$ as he bought the wrong tractor twice and had to buy back a trade in. "Junior, you better hang onto that open station 375." Junior, oh **** what do I need with two tractors?" A week later they brought it back.
We have dents, scars etc. scattered around, but he really got good; put LOTS of hours in.
   / Shuttle Shift or Hydrostatic..... #55
It is becoming more common across brand lines.
   / Shuttle Shift or Hydrostatic..... #57
The Kubota Grand series has the auto-throttle.
They or perhaps JD I think were the firsts. Now it is filtering down the brands.
   / Shuttle Shift or Hydrostatic..... #58
I'm from the other camp, I have two hydrostatic transmissions one is in the little JD 110 lawn mower the other is in my Kubota F2000 mower I like them in the lawn stuff even though the one in the JD is a weak kneed piece of crap.
All the tractors I run are all different types and styles 5 are full powershift and couple with power shuttles and the power shift, the others are a variety of conventional geared units from 4 speeds with a high low range to five speeds and eight speeds.
The full powershift with the power shuttle is in my mind the best transmission and they get used for a large amount of loader work, loading feed daily in the winter for several hundred head of cows.
My main yard and driveway tractor is a four speed three range transmission with a power shuttle it also sees a lot of loader and back or front blade work and brush hogging, once in a great while I would rather have a hydro but that's rare and far between.
My personal preferences and these are just that;
1) power shift with a power shuttle
2) geared with a power shuttle
3) synchronized mechanical shuttle with a geared transmission
4) would be a hydro
5) non-synchronized shuttle
6) conventional geared
just my :2cents:
   / Shuttle Shift or Hydrostatic..... #59
I used to have a saying that I coined myself. I didn't set well with some folks, but I pretty much still believe it is correct. "If you have to ask, you need a hydro"
Here is my thinking on the validity of that statement. If you are an experienced tractor user, and have used various transmissions over the years including all of the variations of the shuttle from the unsynchronized ones up to the Kubota Glideshift which is an extremely complicated, but easy to use and apparently very reliable transmission, then you would not ask. You would KNOW which transmission you needed. But since you have to ask, that means you do not know. And since you do not know, you may or may not be capable right out of the gate of taking the care that is needed for long clutch life. Clutches are fairly easily ruined by novice operators. Hydro machines are bullet proof from novice operators.
Now I could be full of "beans" or something else, but this is what I think.
I think if you make a lot of directional changes as in loader/grapple work of any kind, anyone novice or no will profit from a hydro machine. If you plow in straight lines and rarely change directions or need to vary speed much you will profit from sort of gear machine of which the shuttle tries to improve on maneuverability and more rapid directional changes, but is still basically a gear machine. A mechanical shuttle where you have to clutch all the time to change direction and change gears would be JUST about the last transmission in the world I would choose.
From what you have said your uses are, you need a hydro in the worse way.
As for the dealers recommendations about moving slow and creeping and control and precision, I can tell she has never operated either tractor, or has the qualities of both VERY confused.
As you can tell I have strong opinions, and you may take them or leave them, but this is what I think. I wish you well on what ever you choose.
James
I agree with that. When I’m mowing I often slow down for a thick place and or abruptly slow down for a rough spot. Neither are easily done with a shuttle. I just sent the better part of the day spreading dirt around a house so water runs away. I could easily run with an inch of the house with the HST skid steer. Have fun doing that with a clutch. My backhoe is also very precise movement. But in simple terms it’s really an automatic transmission with manually selected gears.
Utility Tilt Trailer (A55787)
Utility Tilt...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
jet ski trailer (A56859)
jet ski trailer...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A57453)
1996 International...
