Shuttle linkage spec/adjustment?
/ Shuttle linkage spec/adjustment? #1
YukonKing
Bronze Member
Whitehorse Yukon Canada
2021 L2501 FEL
Hello All,
I have been the owner of my JM254 new since 2007. I now have 500 hrs on it. I have had little issues and none that have needed research lately. My new problem is with the shuttle shift. I have adjusted it many times because it wouldn't engage in one of the directions with success everytime.
However now it seems to be getting caught partially in gear in one of the directions and I can't get it out by moving the linkage. This is not a constant problem and has fixed itself twice by coming out of this in-between gear issue. I'm sure i can figure it out by playing with it, but....does anybody have the specs or procedure for setting up the shuttle linkage?
pressure washer, and trailer (A56859)
pressure washer...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2017 Komatsu PC138USLC (A60462)
2017 Komatsu...
excavator trenching bucket- one bucket per lot (A61307)
excavator...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 HayToter Hay Trailer (A60463)
2025 HayToter Hay...
