Rotary Cutter Shulte Rotary Cutter
   / Shulte Rotary Cutter #31
That "brush hog" looks unbreakable, and probably cost 5x what most spend for brush hog. It's impressive!
Did your tractor ever bog down, as not enough PTO HP?
   / Shulte Rotary Cutter #32
Just ran it for the first time, worked great. First impressions is that it is like having a 16' trailer hooked to you at all times, swing wide, don't Jack-knife it, backing is fun, etc.
Backing is fun... NOT! Ha! I've found that pull-types are great going forward, but mine doesn't backup as good as a bass boat trailer. :)
Looks like a beast of a cutter though. Enjoy.
   / Shulte Rotary Cutter #33
After using a pull type cutter a while backing up really isn't a problem.
Power seems fine to me, it maintains 540 PTO RPM no problem and I am probably 90% throttle.
I borrowed a 7' and put it through its paces to make sure I was satisfied with the power before making this big of a purchase.
If the grass is really tall, I will just scoot over some and cut less than a full swath if needed.
I have some pasture that hasn't been cut or grazed in 5+ years and if I have time I will make a video cutting it to show everyone how it does.
   / Shulte Rotary Cutter #35
Backing up should not be a problem. If you want to experience a "backing up" problem - try a true farm wagon. I'm FINALLY able to back mine up - and go where I want it to - for about 100 feet.
   / Shulte Rotary Cutter #36
That sir, is an art, I have NOT mastered. Congrats!
   / Shulte Rotary Cutter #37
Yea - well, after seven years of practice - something has gotta happen. Either I DO get better or I sell my darn farm wagon. I think God made farm wagons just to humble folks. Try hooking your tractor up to this and backing it thru a grove of ancient Ponderosa pines. After so many years - I just got tired of always trying to find an exit route that meant driving forward.
Ran it for about 30 minutes before the rain moved in.
   / Shulte Rotary Cutter #39
Those Horst gears are so nice and tight, I find them quite easy to back up... It's the old wore out ones that are harder...
SR
   / Shulte Rotary Cutter #40
Nice picture! About the only thing missing is Toto floating through the air...
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2380 (A58376)
2380 (A58376)
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
2006 CATERPILLAR 304C (A58216)
2006 CATERPILLAR...
