shudder in the steering wheel
   / shudder in the steering wheel #1
jrdellaratta
Howard County, MD
JD 990
While using my 990 for some cutting this weekedn, I would get a slight shudder in the steering wheel when making sharper/90 degree turns. I didn't think until now, sitting at work, to check my fluid levels---could being low on power steering fluid account for this shudder?
Thanks.
   / shudder in the steering wheel #2
Were you turning the wheel fairly quickly? The steering mechanism on my 990 also shudders if you turn the wheel too fast. Turn it a bit slower and it's OK. Also, if you rev the engine up it gets better than when idling, so I suspect it's just a matter of the steering pump being unable to keep up with the fluid demand when spinning the wheel fast. I doubt there is anything wrong, at least in my case.
   / shudder in the steering wheel #3
Mine does the same thing. It is a bit less noticable if you run in 2WD.
Thanks for the responses. In fact I was doing alot of 270 degree turns, cutting a smaller area that usually gets mowed with my ZTR, which I had let get too long over the past month.
Thanks again.
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
2015 Mazda 3 Sedan (A55758)
2015 Mazda 3 Sedan...
2005 JLG 660SJ Manlift (A54865)
2005 JLG 660SJ...
2016 CATERPILLAR 315FL CR EXCAVATOR (A52706)
2016 CATERPILLAR...
500 Gallon Fuel Tank (A53314)
500 Gallon Fuel...
Wolverine SBM-12-72W (A53316)
Wolverine...
