shudder in the steering wheel
   / shudder in the steering wheel #1
jrdellaratta
Howard County, MD
JD 990
While using my 990 for some cutting this weekedn, I would get a slight shudder in the steering wheel when making sharper/90 degree turns. I didn't think until now, sitting at work, to check my fluid levels---could being low on power steering fluid account for this shudder?
Thanks.
   / shudder in the steering wheel #2
Were you turning the wheel fairly quickly? The steering mechanism on my 990 also shudders if you turn the wheel too fast. Turn it a bit slower and it's OK. Also, if you rev the engine up it gets better than when idling, so I suspect it's just a matter of the steering pump being unable to keep up with the fluid demand when spinning the wheel fast. I doubt there is anything wrong, at least in my case.
   / shudder in the steering wheel #3
Mine does the same thing. It is a bit less noticable if you run in 2WD.
Thanks for the responses. In fact I was doing alot of 270 degree turns, cutting a smaller area that usually gets mowed with my ZTR, which I had let get too long over the past month.
Thanks again.
Ford 670 (A53314)
Ford 670 (A53314)
Year: 2009 Make: Freightliner Model: B2 Vehicle Type: Bus Mileage: Plate: Body Type: Conventional (A55852)
Year: 2009 Make...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2008 Ford F-350 Pickup Truck (A55852)
2008 Ford F-350...
IR SDLGC80 Electric Golf Cart (A53316)
IR SDLGC80...
