Shredder front guards
/ Shredder front guards #1
Aggie66
Rockdale TX
MX 5400
I have a Landpride 2072 shredder and the rubber front guards are ripping off. I've looked at Chains and they are close to $300. Rubber replacements are $25. Has anyone used anything different that is more durable than the 1/4 inch or 3/8 inch whatever it is or should I just go ahead and rebuy the rubber replacements...thanks.
/ Shredder front guards #2
Aggie66, On my Woods shredder I just measured the length, height, & thickness of the old one and bought a roll of used conveyer belting to make replacements with. It's been holding up fine so far and I have enough left over that I can easily make any needed replacements as the need arises. Was much cheaper than buying replacements from Woods, or changing over to chains!! Look for repurposed belting.
Greg
/ Shredder front guards #3
Greg
What he said.
Belting is way tougher and you could probably find some used cheap or free.
Worst case buy some new and it will last.
Thanks that’s what I’ll do
/ Shredder front guards #5
I can only suggest chains for guards. It's the way to go.
Not hard to fabricate yourself if you have basic tooling, a little bit time consuming but 100% worth it.
110% of the cutters sold here have chains.
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59911)
2016 INTERNATIONAL...
Case SV280B (A62177)
EZ Trail 3400 (A63688)
