shredder/chipper attachment modification
/ shredder/chipper attachment modification #11
JJ,
I just went out and checked, and the only tag on the motor just says" Haldex-Barnes", a date, and a number "1300079" that looks more like a serial number than model number. If I come across the invoice it may have more information.
My machine is rated 15 gpm @ 3,200 psi I think. I was looking for something rated around 1800 rpm @ 12 gpm so that I would not have to run the engine wide open, but when I do it spins it at over 2000 I am sure. Runs great though!
The chipper is a BearCat model 73420 manual feed disk-type with 140 lb flywheel & 4 knives. It was available powered by either a 13 or 20 HP (in my case) Honda mounted on a trailer. Worked fine except that the trailer was too tippy to pull back into where most of the slash was, and it took too much time & effort to bring the slash out to the road. Now wherever I can get the PT I can chip away.
This is a chiper only, and not a chipper/shredder although one should be able to do the same thing. As I mentioned, I direct drive the main shaft via a flex coupling completely bypassing any indirect drives used with PTO shaft inputs. I can put everything back like it was in probably an hour or two.
Yes, a motor spool valve has the over-running function built-in, but I hooked this up like a mower head so I just turn the PTO switch ON and OFF. I will usually have the engine at fast idle when I turn it on and then ramp it up to whatever speed I want. I also idle it down for 30 seconds or so before turning the PTO switch off. The check valve between the in & out side of the motor seems to take care of the over-running issue. All hoses & fittings are 3/4".
Going out of town for a few days... will be happy to answer any more questions when I get back.
I decided to pass on doing a chipper modification for now, since I really need to get a chipper now to clear some shrubs and trees from my backlot. I know that the chipper modification would probably languish for awhile.
I keep a close watch on craigslist; they have them setup so I can dump an RSS feed for the tools for sale list straight onto MY YAHOO homepage, so I can watch the four or five nearby cities without any effort.
The mighty mac shredder that I was looking at looks like it is similar to a TPH-122, but with a slightly different mounting scheme, and maybe without the branch chute. Hard to tell from the pictures. For $200, it seems like a steal (retail for the TPH-122 is $1700+).
http://hartford.craigslist.org/tls/142846388.html
The Mackissick home page is here:
http://www.mackissic.com/consumer/threeconsumer/threepoint.htm
/ shredder/chipper attachment modification #13
Tim,
That MacKissic appears to be a shredder only, without the heavy flywheel and cutting knives to chip with -- only the hammer-mill type flails. They made both versions to fit old garden tractors.
That's likely the reason that one is so reasonably priced.
I know a couple of guys who have those for Simplicity tractors. They do a good job on leaves, garden plants, and 1" twigs or less, but can't chip limbs.
Simplicity Attachment Catalog from 1977
/ shredder/chipper attachment modification #14
Yeah.... my BearCat is a disc (or flywheel) type wood chipper only. It does not even do much with ponderosa pine needles except spit them out. However, most mulchers, shredders or chipper/shredders that are engine or PTO driven can be adapted to hydraulic. Just have to make sure hp and speed requirments are taken into account.
/ shredder/chipper attachment modification #15
Tim I live in Brookly CT I just saw a ford drum chipper for sale in the Turnpike Buyer for $500 running I will look for the # if interrested
/ shredder/chipper attachment modification #16
Have you tried Baileynet.com for your hydraulic supplies?
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
Kubota B2301 (A53317)
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
