show your short drop storage solutions
   / show your short drop storage solutions #1
jwmorris
I have built a swing out rack for material from 16" to 8' or so that makes it quick to find a section that I need but am looking for something for the buckets of drop that I have that are shorter. Rotating bins would be nice but they are quite expensive if they can hold the weight. What have you come up with?
For full length I put together a rack inside a 40' container, up high enough I can still get in with other equipment.
   / show your short drop storage solutions #4
Did you just get through putting it together? That place is neat as a pin!
PH
   / show your short drop storage solutions #5
I also have a container set up in a similar fashion with shelves on both sides and the end. I had a bunch of 3x12 planks and just set them on concrete blocks. I like your steel storage racks but have absolutely no wall space in the garage as it also has plank wall shelves and workbenches on the other side. So, I built very low narrow pallets with various size/length boxes and milk crates for small stuff, just wide enough to go under the bench lengthways. I use a pallet jack to move it out whenever needed. I used to use short pieces of pipe as rollers before getting the jack, but that was sort of a pain.
Can't post photo as it's in NY and I'm in Fla.
   / show your short drop storage solutions #6
JW that stuff is of no use to ya , maybe I can stop by and get it out of your way :D =(too bad U R in Texas... )
Short storage was always an issue and usually we end up getting a pile then tossing most of it in the bin for scrap and getting more out...
We has some 30" gallon Steel Drums that we used for holding a good bit of them usually stuff that was 24"+/- ad for the 12" or less stuff we had a big bent channel of 14awg 10' long and 6" deep x 20" wide on the bottom rack that they were tossed in...
Mark
Most of it could be scrapped but I really hate to throw away stuff. The short stock 4130 seamless tubing is kind of like gold when you are making things, just a cut will do the same thing as machining a part on the lathe. Only off you can put your hands on it quickly...
   / show your short drop storage solutions #8
I have the same problem with the smaller pieces! I have 3 full milk crates fastened together and even though they are on casters, it seems like they are always in my way. I can't see scrapping the pieces either, because I always find a need for what's in there. I think I just need more storage space. :laughing:
   / show your short drop storage solutions #9
I swear stock storage is one of the more challenging things out there. I had that problem when I was model-making as a teenager, and I have that problem now. As a temporary solution I've thrown short drops and scrap in 5-gallon buckets; one for flats, another for square/rectangular tubing, one for round tubing, and so on. It's not a great solution; but it beats the one I used to do, which was just throw everything in a pile on the floor. I just hate how heavy the buckets get and having to dump the contents out to find something.
A friend had one of these at his shop that would work for what I need and I have been looking for a used one, just can't see spending $1000 on something to save drop material.
5 (15" deep) compartments per shelve with 8 shelves and each one can hold 500#.
34" Rotary Shelving - Rotabins - Lazy Susan rotating steel bins
New JMR 40" Mini Skidloader Flat Bottom Grapple (A50775)
New JMR 40" Mini...
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
2013 DODGE CHARGER SEDAN (A54607)
2013 DODGE CHARGER...
NOBLE R80 ROUGH TERRAIN FORKLIFT (A52705)
NOBLE R80 ROUGH...
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
