show your short drop storage solutions
   / show your short drop storage solutions #1
jwmorris
Veteran Member
I have built a swing out rack for material from 16" to 8' or so that makes it quick to find a section that I need but am looking for something for the buckets of drop that I have that are shorter. Rotating bins would be nice but they are quite expensive if they can hold the weight. What have you come up with?
For full length I put together a rack inside a 40' container, up high enough I can still get in with other equipment.
   / show your short drop storage solutions #4
Did you just get through putting it together? That place is neat as a pin!
PH
   / show your short drop storage solutions #5
I also have a container set up in a similar fashion with shelves on both sides and the end. I had a bunch of 3x12 planks and just set them on concrete blocks. I like your steel storage racks but have absolutely no wall space in the garage as it also has plank wall shelves and workbenches on the other side. So, I built very low narrow pallets with various size/length boxes and milk crates for small stuff, just wide enough to go under the bench lengthways. I use a pallet jack to move it out whenever needed. I used to use short pieces of pipe as rollers before getting the jack, but that was sort of a pain.
Can't post photo as it's in NY and I'm in Fla.
   / show your short drop storage solutions #6
JW that stuff is of no use to ya , maybe I can stop by and get it out of your way :D =(too bad U R in Texas... )
Short storage was always an issue and usually we end up getting a pile then tossing most of it in the bin for scrap and getting more out...
We has some 30" gallon Steel Drums that we used for holding a good bit of them usually stuff that was 24"+/- ad for the 12" or less stuff we had a big bent channel of 14awg 10' long and 6" deep x 20" wide on the bottom rack that they were tossed in...
Mark
Most of it could be scrapped but I really hate to throw away stuff. The short stock 4130 seamless tubing is kind of like gold when you are making things, just a cut will do the same thing as machining a part on the lathe. Only off you can put your hands on it quickly...
   / show your short drop storage solutions #8
I have the same problem with the smaller pieces! I have 3 full milk crates fastened together and even though they are on casters, it seems like they are always in my way. I can't see scrapping the pieces either, because I always find a need for what's in there. I think I just need more storage space. :laughing:
   / show your short drop storage solutions #9
I swear stock storage is one of the more challenging things out there. I had that problem when I was model-making as a teenager, and I have that problem now. As a temporary solution I've thrown short drops and scrap in 5-gallon buckets; one for flats, another for square/rectangular tubing, one for round tubing, and so on. It's not a great solution; but it beats the one I used to do, which was just throw everything in a pile on the floor. I just hate how heavy the buckets get and having to dump the contents out to find something.
A friend had one of these at his shop that would work for what I need and I have been looking for a used one, just can't see spending $1000 on something to save drop material.
5 (15" deep) compartments per shelve with 8 shelves and each one can hold 500#.
34" Rotary Shelving - Rotabins - Lazy Susan rotating steel bins
2017 KUBOTA SVL75-2 SKID STEER (A52705)
2017 KUBOTA...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
Golf Cart (A55787)
Golf Cart (A55787)
