Should piston spin freely on shaft?
   / Should piston spin freely on shaft?
Picture #1 looks like the threads on the shaft stop before the nut could pull tight. So was there a spacer on? or the nut was cut so fits over the shafwasher to be put t to pull tight to piston. What ever motion will cause added wear beating forward or backward before fluid pressure took up the space.
Try to locate manufacture of cyl. or book on the back hoe for information.
I just hate to locate a spacer after the machine is working in the bottom of the container for washing parts.
ken
In the picture I just didn't have anything tight. Bad pictures anyway plus the junky back ground.
There were no spacers but I have been known to clean out the parts washer and WHOA where did this suppose to go.:confused:
I got it torqued and everything appears OK. I'll stick it back on maybe tomorrow. Thanks.
   / Should piston spin freely on shaft? #22
Torque specs for piston nut. Again, the piston is not supposed to move on the shaft given the torque specs. The figures are in ft lbs.
Locknut Size
½ - 20
5/8 - 18
¾ - 16
7/8 - 14
1 - 14
1 1/8 - 12
1 ¼ - 12
Clamp Load (lbs)
8,997
14,398
20,979
28,658
38,244
48,134
60,353
Torque Min (ft-lbs)
32
64
111
178
271
384
534
Torque Max (ft-lbs)
43
86
151
240
367
519
723
Return to top of page
Awfully loose. I would expect nearer twice those figures.
larry
   / Should piston spin freely on shaft? #23
I agree there's a lot of confusing info on torque settings. It seems like every chart is a little different and most of them will say there info is approximate and to always check with the manufacturer. Well since I haven't had any luck finding the manufacturer I'll go by the charts available.
The one I used is from MTI ( Torque Chart ) and at the bottom of the list it says add 33% for dry or deduct 45% for lubricated threads. It come up somewhere close to 700 ft lbs and that is what I used.
I was assuming the shaft was equal to a grade 5?? and I don't have a torque wrench to read this high so it's all an estimate anyway, I estimated the weight applied to the cheater bar and the distance to get my torque. At my weight only a short cheater is needed:D
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
