Should I Paint my Carry All?
   / Should I Paint my Carry All? #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
I'm retired, have the time, just finished building a greenhouse for my wife, and am planning on building a Carry All. Just have to keep busy. I've seen most of the You Tube Videos on building a carry all and most of them use pressure treated wood.
I'm toying with the idea of using 2" non-pressure treated boards and painting them John Deere green. Opinions wanted, but don't comment if you think I'm crazy to do it . . . just looking for pros and cons.
Thanks,
FredSG
   / Should I Paint my Carry All? #3
Paint or any other sealant protects material. It will make it last longer. Doesn't matter if we are talking metal & rust or wood & rot.
   / Should I Paint my Carry All? #4
When I built mine about 10 years ago I used some old non-treated 2x's I had laying around, treated them with a few coats used engine oil letting it soak in the hot sun between each until it was absorbed. Sits outside all the time and still has the same boards on it, still solid.
   / Should I Paint my Carry All? #5
Nothing wrong with painting non PT wood, most trim on houses painted wood. Depending on weather and sun good exterior paint should last .:drink:
   / Should I Paint my Carry All? #6
Nothing wrong with your plan. Just use a good exterior primer.
   / Should I Paint my Carry All? #7
Painted wood decking boards on piers seem to hold up well, even though they are just above the water. They usually don't fail simultaneously. Make them easy to replace individually.
   / Should I Paint my Carry All? #8
Friend built a small horse coral. He treat the post ends in boiling linseed oil and diesel fuel. No idea where he got this formula. 55 gallon barrel and propane fired weed burner. A real explosive situation. However - he kept the posts in this boiling concoction for about four hours. They are still rock solid after thirty years.
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Dewalt DWM120 5" Deep Cut Variable Speed Band Saw (A59076)
Dewalt DWM120 5"...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
