Should I just sell it for scrap
   / Should I just sell it for scrap
Thanks for your response Al,
Yes, the spring turned out to be part of the Draft control dash-pot. I found the rest of the parts on bottom of case.
And yes, the only way to replace the pump (with multi-power, is to split the tractor.
I found a 1/4" x 5/8" bolt on the bottom of case that I could not see where it could go.
Preliminarily the pump seems to be working good. Will attach a grading box and try it today.
Gary
   / Should I just sell it for scrap #12
great to hear!
Thanks Soundguy,
It is working fine. Got some grading done with this heavy 5.5' "Bush Hog grading box. So much that I broke the lower lift arm. Come to find out, it wasn't the right (not as long or thick) one anyways. New one came ups today.
The only thing I worry about is the transmission. I can only find 1st and reverse. For now that's fine. But someday I may sell it and would like to have all the gears working. The shifter just won't go over there. Anyone have any thoughts?
Thanks,
Gary
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
