Should I install a block heater?
/ Should I install a block heater? #21
Philip,
I've only had two Kubota tractors, so my comments are only based on them. My BX fired right up at -30 with no block heater needed whatsoever. Kubotas are fairly well known as good, cold weather starters. No doubt. But my goodness, the racket of a D722 engine starting at -30F sounds awful!!! It sounded like ball bearing were bouncing around in it. A problem? Probably not one bit, except to my sensibilities. It gave me the heebie jeebies.
However, when I got the B2320, one option I absolutely wanted with the block heater. It had nothing to do with its ability to actually start as I wasn't worried about that.
It's just that I promised my new D1005 I'd never do that to it.:D
/ Should I install a block heater? #22
Get the block heater.
Get an all weather time if you have a predictable schedule and let it heat for an hour before you get there. Mine lets me get to plowing snow in the a.m. with a clear conscience.
They are cheap and effective insurance against engine wear.
/ Should I install a block heater? #23
This is all very interesting to one who lives north of the 49th. I don't now nor have ever owned a diesel new or not that will fire right up at -20F after it has been cold soaked for several days. A block heater is a necessity and if there is room two block heaters plus an oil pan heater.
/ Should I install a block heater? #24
5 am. Below zero. 10" of snow to push with more coming. Plug in the block heater, go do your morning S.S.S., have a second cup of coffee with some toast, blab a bit on TBN, check your email, watch a weather radar or two, and 2 hours have passed and it's 7 a.m. and it's finally getting light enough to see. Glow the plugs for 4 Mississippi's and she roars to life. The temp gauge is already up 1/3. Priceless.
Both mine stay in the Clearspan and I follow your routine minus the block heaters. I run 5-40 Rotella in the winter. Go start them, 15 seconds on the glow plugs if below 0. If above zero no glow, just a sliightly longer crank.
I let 'em idle while I go back inside for coffee and my morning sabatical and then I'm ready to go out. The cab is warm, the fm is tuned to my favorite hillbilly station and I'm ready to clear the road.
Kubota's start well in cold temperatures becaue the injection pump has an internal mechanical fuel advance that gives 100% fuel until the engine fires. That and the high base compression ratio makes for good cold weather starts.
/ Should I install a block heater? #25
Some will start without a block heater, others won't. Just need to know which tractor you have, one that will, or one that won't. Intentionally cold started ours, just to see if it would, and it did. If you are talking about those magnetic oil Pan heaters, they are nothing more than a novelty, not worth the time, especially on a cast iron pan.
/ Should I install a block heater? #26
I haven't seen a cast iron pan on a tractor in 30 years. The only cast iron pan I know of is the one the missus makes my eggs in for breakfast.:D
/ Should I install a block heater? #27
I'm talking the kind you glue to the bottom of the pan and are sized to the oil capacity.
As for which one will or not start. Of the 25 diesels I have there is not one that will start after a minus 20 F cold soaking of at least 48 hrs. Enough ether and a line up of batteries for jumping and ya they will go but then what have I proven.
-20 in an enclosed building and sitting over night after running is not a test of how well and engine will start.
/ Should I install a block heater? #31
I agree with you. i live in north Idaho, and i really done want to damage my engine in the cold. Sure it might start, but its not good to do this on a very cold day. Pre-heating the oil just seems like a logical thing to do. I also understand that a tractor out in the Forest on a timber project cant plug in and needs ether to start. then again, Ive seen what these pieces of equipment look like in 5 years, and i don't want mine to blow black smoke all day long. A 250 watt heater costs me less than 2 cents per hour to operate, so whats the big deal. Running the tractor for 15-20 minutes to warm up costs alot more $$$$,
/ Should I install a block heater? #32
If it were me, the deciding factor it would revolve around wether the tractor was out in the weather, or stored inside (pole barn, shed, garage...).
On my B2920, I've found that having it in my unheated garage seems to make a marked difference in tempreture, between inside and outside.
And I've never had a problem starting my Kubota. For the first 2 years I did not know the keyposition for the preheater, so I never used them, yet the tractor started up each and every time.
So if it's inside (anything), you shouldn't need a engine block heater, if it's outside, then yes.
/ Should I install a block heater? #33
Amen to that!!!:thumbsup:
/ Should I install a block heater? #34
Just listening to my tractor idle the first couple of minutes after I start it in cold weather(it starts great either plugged in or not down to -40)but just listening to it run those first couple of minutes makes me plug it in now whenever I can even if it isn't that cold.
Rick
/ Should I install a block heater? #35
[/QUOTE]So if it's inside (anything), you shouldn't need a engine block heater, if it's outside, then yes./QUOTE]
If the enclosure is not heated; inside and outside temperatures will be the same.:)
/ Should I install a block heater? #36
If the enclosure is not heated; inside and outside temperatures will be the same.:)[/quote]
yes and no...my garage is unheated but stays warmer than outside. And my enclosed shop feels warmer then outside..but thats probibly due to wind chill. My tractor is in an open ended lean to, no heat. BURRRR
/ Should I install a block heater? #37
yes and no...my garage is unheated but stays warmer than outside. BURRRR[/QUOTE said:
Is your garage attached to the house?
/ Should I install a block heater? #38
Get a block heater from Kubota and install it. They install easy and are cheap insurance on that tractor lasting a lifetime. Makes me feel better that I have and use one and I am sure it helps the ttractor out in the long run. JMO.
/ Should I install a block heater? #39
Rick
The cackle is compression at work. Nothing else.
If the enclosure is not heated; inside and outside temperatures will be the same.:)[/QUOTE]
If the tractor is inside an enclosure (like my Clearspan), the inside temperature is about what it is outside with an important consideration....Inside the unit is out of the wind and resultant windchill which causes hard cold starts
My 2 cost as much as 6 of yours and I have no need for a block heater. I never have in ther last 13 Kubota's I've owned.
/ Should I install a block heater? #40
A word of advice to those that have block heaters.
Just because the coolant is warm(which is all the block heater does), doesn't mean your engine oil is warm(which sits in the pan below the block), and it doesn't mean your hydraulic oil is warm.
The hydraulic oil needs to be warmed also(especially in a hydro machine), or serious damage can result.
I only mention this because sometimes people have the misconception that since the engine starts easy, we can start and go. Such is not the case.
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
