Tires Should I do this tire swap??
   / Should I do this tire swap??
Yes, they are willing to load the tires for no extra cost to me.
John M
Also, one MORE question. Does the group feel I am reducing resale or value of the tractor by going with the R1 tires? It seems that many like the R1 tires, but I see very few machines on lots with the R1's. They all seem to have the R4's. I just plowed about 5" of snow this PM with the front blade. The tractor does great, but I wonder if the R1's would substantially help plowing on some of these steep hills we have here. Although I have not had trouble, the tractor did slide sideways some on one particularly steep area of the road in front of my house.
John M
   / Should I do this tire swap?? #13
John, Ive plowed snow with my old JD 870w/R1's and 84" front blade for 12 years. I can't recall in that 12 years of ever having slid down a hill while plowing in 4 wheel drive. Now I've have had it spin up hill while plowing.
I currently have a 3520w/R4's with same 84" front blade. I can't say how it will do, but I think it will get interesting with the R4's and snow.
As far as resale of your tractor with R1's. The average buyer is probably looking for R4 equiped tractor. Just because thats whats popular right now.
How much will it hurt the resale price..............can't say.
After 100 hours on the 3520w/ R4's I can say that my preference is for R1's in my application.
   / Should I do this tire swap?? #14
jcmseven said:
Fellow Posters:
I have a 3720 which currently has R4 tires. I have been happy with the R4 tires, and they are loaded to add stability when doing loader work, etc. My local dealer--not the one from whom I purchased the tractor but still know and with whom I do regular business--has a 3320 they received for a customer with R1 tires. My salesman at the dealership said the order was a mistake and they were trying to obtain a set of R4 tires for it. I do mainly ground engagement work, such as box blading my drive, loader work, and such. I also just received my Frontier front blade in case we have snow. I do wish to mow some with the tractor, but mowing is something I do for to help my parents as I have no grass on my property. It appears the 3000 series with R1 tires are more narrow also, which would be an attribute as well for me due to my many tight areas. I was thinking of trading my R4 tires for the R1's to help both the dealer and me. I am hoping the R1's would be a better choice for snow removal and might eliminate a need for chains in most cases (although I have not had problems with the R4 tires either). Should I do this??? I am not enthralled with the look of the R1's and I do run on the road some. I also trade tractors fairly often and do not want to reduce my machine's marketability when and if I were to trade--which I have no plans of doing now. Also, is the swap a direct swap from tractor to tractor, or are there adapters, etc., which would be needed??
John M
I have two 30 hp 4x4 tractors with loaders; one has R-1's, and the other tractor has R-4 's. Doing loader work in soil conditions the R-1's win! On hard surface, the R-1's win again, but the front tires being narrower, suffer more stress because of the weight distribution over a smaller area. You will lose money by trading your R-4's, since they are more popular for resale. My R-4's cost $400+ over the R-1's. When I need traction the R-1's provide it. With my small fleet of tractors, only two of them have R-4's. You will take a financial hit now if you trade across; then again when you trade for a new tractor?
   / Should I do this tire swap?? #15
I was just cursing my R4's last week when I was trying to load some brush piles onto a burn pile with my grapple. I couldn't hardly move and had to use the grapple to get unstuck many times.:mad: If I had it to do over I would probably go with the R1's for my application. I will say that mud is the big issue, not necessarily snow.
It may be a case where people like me thought they wanted the R4's but after running with them for a while realize they aren't really what they need. The problem is it costs a good bit of money to change them out so we just live with it. I've been looking at chains to use when it's muddy to fix the problem.
Is it a new tractor? How can the dealer get away with selling a new tractor with used tires on it? I'd say used, loaded R4's swapped for new, loaded R1's isn't a bad trade. I think I'd be all over it.
Partsman,
Yes, the tractor with the R1 tires is new. Mine though only has 45 hours on it, and I keep it in like new shape, and wash it often. There is no notable wear on my tires. Since the R1 tires are the base tires, I figure the dealer will just sell the tractor with the R1 tire price, essentially giving the customer the R4 tires for no extra charge. I then would get the R1 tires. The dealer saves on shipping a set of R4's and I get a tire more suitable to my needs. As far as resale, I have no plans to sell my tractor. I have traded a few times recently, mainly to settle on what I really needed, which I now feel I have. I plan to keep this machine a while, and losing a little on sell or trade would not be horrible. If worse happens, I would just offer to put on a set of R4 tires before trading. My only concern is I did not want to do this if it would offer no real benefit, but it seems that it will.
John M
   / Should I do this tire swap?? #17
JOHN: You will be amazed with the additional traction that R-1's provide! As mentioned, the R-4's load up in mud, turning to "slicks" and won't self clean, which will leave a trail when returning to a hard surface requiring clean-up. If you plan on keeping the tractor with traction and issue, make the trade. You will get a slight bumpy ride on hard surfaces with the R-1's, but the traction gain is worth it. Good luck on your decision.
   / Should I do this tire swap?? #18
I do not think you will lose resale value on the trade. When I was looking for a used tractor , I wanted R-1 for traction value. At first I thought, I could buy a good tractor and swap out tires. With the additional cost of 1,200 to 2,000 it was going make more sense to buy new. I finally found the right used tractor with the right tires (R-1) and quickly bought. I think your dealer owes you a favor some where down the line.
John
   / Should I do this tire swap?? #19
John, if you go with the R1's and then decide to trade tractors you can't just put a set of R4's on without changing wheels also. R1 and R4 wheels are not the same at least on the rear.
Dirtworks,
I would probably buy the tire and wheel combo if I were to trade and had someone wanting the R4's. The dealer from whom I actually bought the tractor says he rarely sells R1's there. I suppose because the terrain is not as challenging, the R1 tires do not move as fast there. I think I am going to get the R1's. Just the width change alone would be worth it so that I can get into some tighter spaces in back. The traction also seems worth it, although I must admit I do not mind the R4 so far.
John M
Deere 410L (A53317)
Deere 410L (A53317)
2018 Generac S/A Towable Light Tower (A55973)
2018 Generac S/A...
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
UNUSED FUTURE 32"...
