Ok folks, fire away with your opinions ....
I have a 13hp Honda horizontal shaft engine and a 8 gpm pump. I have scavenged these parts so far for next to nothing and I am building a hydraulic power pack to run a log splitter and other hydraulic chores.
Here is my question. The 8 gpm should work fine for the splitter, but I like the idea of having quicker cycle times that a two stage pump can deliver. The one limiting factor is that the hoses I intend to use are 1/2".
Should I switch to a pump like this:
Haldex Hydraulic Pump — 22 GPM, 2-Stage, Model# 1080035 | Pumps | Northern Tool + Equipment
Or possibly this:
Haldex Hydraulic Pump — 28 GPM, 2-Stage, Model# 1080036 | Pumps | Northern Tool + Equipment
The motor should run the first one fine and with the right adjustments on the 2nd stage cutoff valve, the larger one would work as well. The only issue I see (besides spending money ... but hopefully eBay should get the prices down a bit), is that these pumps have 1" outputs which somewhat will comprimise their benifits.
My dilema is that while more faster would be good, there are are drawbacks as well:
1- When splitting logs, the 8 gpm should move things along and with the detent valve, I don't have to stay next to the splitter when it returns its cycle
2- What I have now paid for so that solution is free
3- As mentioned, the 1" output will be restricted by 1/2" hoses
4- On the plus side, the wood I usually get splits pretty easy so it may not even kick in the low gear side of the pump that much and that would be worth the price given the time savings.
Let me know what you think. The concern I would have about the 22 gpm pump is that it only puts out 3.5 gpm in "low gear" and my current pump puts out 8 gpm. FYI - the splitter that this will be used with (when I am splitting wood) uses a 4-way splitter with a 4x24 ram.
Or possibly this:
