Should i buy this Mule 610XC
   / Should i buy this Mule 610XC #1
BoneDigger
Tyler, TX
2015 New Holland Workmast 35
I have a line on a 2011 model in blue and black that an older man and his wife used for hunting, with no mud use. It has right at 40 hours. He wants $6500. The best I have found new is around 7900 OTD after tax.
So, deal or no deal on the 610XC for $6500?
Todd
   / Should i buy this Mule 610XC #2
No you should not buy it. You should tell me where it is so I can go buy it.:laughing::laughing:
Thanks, i'll keep that in mind! :)
Anyone else?
Todd
   / Should i buy this Mule 610XC #4
I'm rather happy with my 610xc. But it has four problems.
I use it in such short trips that I discharge the battery.
I had starting problems until I learned the trick of half throttle on the accelerator when starting.
The front trunk latches sometimes engaged improperly causing opening difficulty so I just removed them (four screws) and let gravity keep the cover closed.
The mules have difficulty going from low to high. The solution is to blip the throttle or use the high range as much as possible.
It's a real convenience to drop my tools in the rear trunk before going out to the work site. You might consider getting a 3for1 hook for pulling a small trailer. I traded a atv in for this utv and I've never regretted it.
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
LOT: Kimball Midwest 4-Drawer Hardware Cabinet w/Contents & Stand (A59076)
LOT: Kimball...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A58375)
UNUSED CFG...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
2010 SHOP MADE MARATHON 25KW GENERATOR (A58216)
2010 SHOP MADE...
NEW HOLLAND TS115A TRACTOR (A58375)
NEW HOLLAND TS115A...
