Rotary Cutter Should I buy a Kodiak HD 10' Brush Hog?
   / Should I buy a Kodiak HD 10' Brush Hog? #1
irunjohndeere
HARRISVILLE, WV
190 Allis Chalmers, 185 Allis Chalmers, D17 Allis Chalmers, Massey 65, John Deere 540 Skidder, 350C John Deere Dozer
I have found a 2013 or 2014 Kodiak HD 10' pull type brush hog for sale and wondering what it was worth? It had normal wear with one of the back and side shields bent in. A new one is $6200. I was also wondering how Kodiak brush hogs hold up compared to other better known brush hogs? Do Kodiak brush hogs have any known issues?
Thanks for your comments/advice.
   / Should I buy a Kodiak HD 10' Brush Hog? #2
Helloirunjohndeere,
About the Kodiak 10 footer you should send Island Tractor a PM as he owns a small Kodiak rotary cutter.
Its better for you to find out why they are selling it before you go further as many broken welds come from the steel sheets flexing over time.
Unless you can flip it over or stand it up to look underneath at the stump jumpers if it has them or look at the weld gussets to strengthen the steel around the gearboxes your gambling. The other thing to check is the rear wheel mounts and welds on tubes used for the wheels if it has rear caster wheels too.
Having the side and rear debris shields bent in is never good but until you look at it and take a 4 pound hammer with you to bang welds and use parts cleaner to check for broken welds with a wire brush you will not know whether its worth buying.
The cost comes close to a new john Deere 290 flail or a 6-7 foot Vrisimo flail mower.
   / Should I buy a Kodiak HD 10' Brush Hog? #3
What are they asking for it? Kodiak is a brand that mahindra sells I think. Not one of the big names but I don't think that means any less of quality either. I'd look it over real well and check on part availability. If you have to haul it much at all you'd be better suited with an 8' but that 10' will cover some ground
Brett
2020 Trailerman Trailer (A50514)
2020 Trailerman...
Case 580 Backhoe Loader (A50514)
Case 580 Backhoe...
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
