Should I Buy a "Bushhog" brand cutter
   / Should I Buy a "Bushhog" brand cutter #21
Re: Should I Buy a \"Bushhog\" brand cutter
Yeah, a slight difference there, JimI./w3tcompact/icons/wink.gif
   / Should I Buy a "Bushhog" brand cutter #22
Re: Should I Buy a "Bushhog" brand cutter
i get to use a brown tcf2620 and all i can say is it`s awsome
flip of a hydl. flap go`es up and back over a 6 in pine. it`s a mean cutter . bush hog make a good cutter but for heavy duty cutting brown is ahead of the game . just looking at it you can tell it`s tuff. just my thought of the day :)
John it is being pulled by my new Tc40 with 4wd.
<font color=blue>...A more powerful tractor would certainly benefit this cutter...</font color=blue>
Ain't that always the case.../w3tcompact/icons/laugh.gif
You can never have enough... you see the damage a 50 or 60 PTO hp tractor can do with these cutters... it's hard to comprehend how much more a 120 PTO HP tractor can do... besides doing it faster... they turn the debris from dust into evaporation.../w3tcompact/icons/shocked.gif
<font color=blue>...it is being pulled by my new Tc40...</font color=blue>
It is a 3 point hitch unit and not a tow/pull unit...right?
Brown 8" Rotary Cutter...
ITEM Model #TCO-2620 Open Deck
Cutting Width 72"
Cutting Height 1 1/2" to 12"
Deck Width 81"
Frame 3 x 3 x 1/4" Tubing
Deck 1/4" Plate w/reinforced 1/2" side wall
A-Frame 3 x 3 x 1/4" ASAE Hitch Cat. II w/flex link
Weight 2250 Lbs.
Blades 4 - Double offset 5/8 x 6"
Blade Holder 625 Lbs. 1" plate with replaceable alloy bushings
Drive Shaft** Fully shielded - Telescoping w/ 4 disc slip clutch
Tail Wheel 600 x 9 Solid laminated rubber tire, fork mounted, 360 degree caster
Rear Guard/ Rear Deck 2 Coil springs, collapsible push bar type
Gear Box 165 HP w/1 3/4" input shaft and 2" 13/16 " output shaft
Slip Clutch 100 HP - 4 disc slip clutch w/ 4 adjustments w/over-run
H.P. Required* 70 - 100 Horse Power
Material Size 8" Maximum
Hydraulics N/A
RPM Speed 1000 Std. - 540 Opt.
John it is a 3pt hitch unit.
Richard
Good... you had me worried... the 3-point is much more versatile.../w3tcompact/icons/smile.gif
2025 JMR 36in Bucket Mini Skid Steer Attachment (A50322)
2025 JMR 36in...
2000 Chevy 2500 Suburban (A47384)
2000 Chevy 2500...
Haulmaster Quick Hitch (A50515)
Haulmaster Quick...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
Set of Tractor Tracks (A50514)
Set of Tractor...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
