should I block radiator in the winter?
   / should I block radiator in the winter? #11
Robb,
As Kelvin mentioned be sure that you do not restrict the air flow.
   / should I block radiator in the winter? #12
Thanks for all the good advice. I pulled the cap and noticed that the water started getting warm right away not cold with a rush of hot water when it opens, so it looks like my thermo is stuck at least a little open. I couldn't really see any movement of the water. I plan on pulling it in the next few days and then probably looking for a new one.
My fan pulls air through the radiator front to back. I haven't used it much in a situation where the screen became totally plugged, though I have had to clean the screen off.
Now that I know the thermostat is probably bad I hope I haven't shortened the life of my engine using it last winter. I have only put about 110 hours on it and have changed the oil twice (50 hours (break in) and 100 hours) per the manual.
2013 International Derrick Digger Truck (A55973)
2013 International...
2019 TerraGator 7300 Spinner truck (A55315)
2019 TerraGator...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
