Shopping pto shafts. How much overkill do I need?
   / Shopping pto shafts. How much overkill do I need? #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
Looking at pto shafts for my landpride 64 inch snowblower. I have a Mahindra 2538 with 32 pto hp. Looks like I can find many shafts with a tier rating of 4 that can handle 38 or so hp. I have also seen the tier 5 which is very heavy and more money. Now this is not a continuous operating type of equipment. When handling the tier 5 I cannot think that I would ever need anything like that. I did look at a new King Kutter 72 inch tiller and it only had a tier 4 on it. I thought that may be light for that piece. Would you purchase a 5 or a 4?
   / Shopping pto shafts. How much overkill do I need? #2
I'd get the 4.
   / Shopping pto shafts. How much overkill do I need? #3
You need something to brake incase of ....... And that better not be your Tractor !
They appear to be almost the same price but quite a difference in weight. I think it was a 20 dollar diff. Not sure I could ever break a 4 or wear it out but when the much heavier one is sitting there at the same money makes me wonder. Certainly don't want to break my tractor.
   / Shopping pto shafts. How much overkill do I need? #5
Is the shaft supposed to incorporate a shear bolt? many snowblower shafts do. If so, I'd find a shaft with the correct size shearbolt.
Was just looking at that. This is suppose to have a shear bolt. I have to research the size. The blower does have one other bolt in the drive line but two would never hurt.
I do not find any pto shafts heavier than 35 hp with a shear pin at agrisupply. That one may have to do it.
1453 (A57192)
1453 (A57192)
2021 Ford F-450 4x4 Crew Cab Venturo ET12 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
