Shopping pto shafts. How much overkill do I need?
   / Shopping pto shafts. How much overkill do I need? #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
Looking at pto shafts for my landpride 64 inch snowblower. I have a Mahindra 2538 with 32 pto hp. Looks like I can find many shafts with a tier rating of 4 that can handle 38 or so hp. I have also seen the tier 5 which is very heavy and more money. Now this is not a continuous operating type of equipment. When handling the tier 5 I cannot think that I would ever need anything like that. I did look at a new King Kutter 72 inch tiller and it only had a tier 4 on it. I thought that may be light for that piece. Would you purchase a 5 or a 4?
   / Shopping pto shafts. How much overkill do I need? #2
I'd get the 4.
   / Shopping pto shafts. How much overkill do I need? #3
You need something to brake incase of ....... And that better not be your Tractor !
They appear to be almost the same price but quite a difference in weight. I think it was a 20 dollar diff. Not sure I could ever break a 4 or wear it out but when the much heavier one is sitting there at the same money makes me wonder. Certainly don't want to break my tractor.
   / Shopping pto shafts. How much overkill do I need? #5
Is the shaft supposed to incorporate a shear bolt? many snowblower shafts do. If so, I'd find a shaft with the correct size shearbolt.
Was just looking at that. This is suppose to have a shear bolt. I have to research the size. The blower does have one other bolt in the drive line but two would never hurt.
I do not find any pto shafts heavier than 35 hp with a shear pin at agrisupply. That one may have to do it.
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
2019 Caterpillars 299D2 XHP SKIDSTEER (A51242)
2019 Caterpillars...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
CRESCENT SUPPLY 20 CONTAINMENT TRAILER (A50854)
CRESCENT SUPPLY 20...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2008 FREIGHTLINER B2 BUS CHASSIS (A51222)
2008 FREIGHTLINER...
