Shop Tricks
   / Shop Tricks #1
49tandc
N. Central Fla
SAME Argon 50/FEL; IH B414
I found these on a Mopar board I frequent and though about the smart guys over here. Please all your little pearls of wisdom - usually found in the shop, to the bottom of this list. It may be a help to younger members:
Adhesive lead wheel weights (the kind for aluminum wheels) make nice soft inserts for your vise when working on items you don't want jaw-marked.
If you're not allowed to bake metal parts in the oven for better paint adhesion, heat them up with your propane torch. Not only will the paint bond better, but you'll actually burn off impurities.
Using a 20oz. plastic pop bottle with a hole in the top makes for a much-safer carb primer than holding an entire gas can (this was Stretch's but he didn't post it).
No air-hold fitting to replace valve seals or a broken spring? Feed a good bit of soft nylon braided rope into the cylinder through the spark-plug hole at BDC, then rotate the engine until the rope is compressed between the piston and the valves. The valves will stay put. Do your service - then rotate the engine back to the original point, and pull the rope out--make sure you left some hanging out! (Rick Ehrenberg trick)
Broken leaf spring pieces make great slapping spoons and dollies. Fantastic for adjusting door to fender gaps. When welded to a broken air chisel bit and ground to a cutting edge, they are perfect for chiseling thru factory spot welds on floors and frames.
Scratch a bar of soap to fill my fingernails with hard soap so when I'm working in dirty stuff nothing can get under my nails. Then washing is somewhat started.
If you only have a 110 volt welder and want to weld thicker steel use co2 as your shielding gas. Its cheep and it drives the weld deeper into the steel for better penetration. You don稚 want to use it if you are welding thin steel like body panels for the same reason. Use 75/25 or flux core wire.
If you are using flux core wire and don稚 like all the smoke and fumes, try using a SMALL fan near your work. The breeze will keep the smoke and fumes out of your face allowing you to see what you are doing better and best of all, No headache from the fumes.
Paint roller refills with low nap are great for block sanding where the flat boards won't do - like the curve where the quarter panel meets the roof, or the curves on a mid-seventies Chev 1/2 ton. Just wrap them with your chosen grit sandpaper and have at 'er.
Some bolts with washers welded to the head are great for hanging parts for paint. Stand the washer up on end, weld it to the bolt head, and screw the bolt into the part to be painted.
After welding, cutting or grinding, keep busy for at least an hour before leaving as a "fire watch". One hot chunk of slag on that stack of **** in the corner is all it takes.
If you have ever used a magnet in the shop for anything related to metal work you undoubtedly know how frustrating all those shavings that are stuck to it can be. Simply keep your magnet in a plastic baggy when you use it and when you are storing it. The shavings will stick to it but it is easily cleaned by removing the magnet from the baggy over a trash can.
I like to protect my paint when using a jack. I have a piece of roll bar padding on my jack handle incase I get a little careless and smack the valance panels while lifting my car. Pipe insulation will work for this too but the roll bar padding is denser and I had it lying around. I keep n old foam buffing pad around to set on the jack plate so I don稚 scratch any painted surface the jack pad will lift against.
To remove stubborn screw in oil galley plugs... heat it with a torch, and then hit it with penetrating oil when hot, then unscrew the plug. An old timer at a machine shop told me this trick, he's known to be able to extract any broken fastener.. I was worried about the cold on the warm/hot block but so far no cracks.
For rusty parts removal/freeing: 50/50 mix of acetone and ATF makes a great penetrating oil. Only mix what you need as it has a short shelf life, but work tons better then any penetrating oil you can buy.
Got grass, blood, chocolate or grease stains? Use Efferdent (denture cleaner) as a pre-treater. Simply drop two tabs in the bottom of a clean five gallon bucket - pour in enough water to cover whatever you are treating, and wait until the fizzing stops before adding clothes. Let sit overnight, wash the next day.
49T&C
   / Shop Tricks #2
Great tips ... Thanks for sharing
   / Shop Tricks #3
dude thats an awsome post!!!
have an old heater core lying around? they make great blocks to go on your floor jack when using it to support and engine or trans. the material is soft and with the fins it will contour to what ever you push it aginst.
Ive used one several times when lining things up during and engine install.
   / Shop Tricks #5
Thanks for the shop tips; I always like reading/hearing other people's tips and techniques as sometimes they make my life easier.:)
I just finished a little trick that had needed taking care of years ago.
This will probably not apply to those fortunate enough to have inside space for everything; but, for those like myself that are barely fortunate to even have themselves under roof, here is what I do to keep things such as tractor/riding-mower seats dry.
I have acquired a number of those big plastic tubs that cow mineral-licks come in; people with a few hundred head of cattle accumulate these things like a housewife accumulates Walmart sacks.
For several years, I have been turning them bottom-up over the mower seats, tractor seats, saw-mill engine, etc., or anything outside that needs to be inside.
The aggravating problem is that the twelve-sided tubs that I use have about an inch deep reinforcing lip around the top, with twelve little "gussetts", thus making twelve pockets that each hold about one wet hind-ends worth of water.
No matter how careful, it never fails that the tub will snag on something on it's way up and off whatever seat it is protecting and dribble the contents of that water-holding lip onto the nice dry seat.
So.................., today, after that happening one time too many, I took the cordless drill with a 3/16 bit and poked two holes through each and every little water-pocket around the rims of the tubs, thus curing that problem for now and all time to come.
I hope that this little bit of information will be of use to someone else.;)
   / Shop Tricks #6
When a bolt head or a nut gets rounded and it is down a hole where you can only get to it with a 12 or 18 inch extention , like exhaust manifold to pipe connections, I heat the nut or bolt head red and pound on the next smalled 12 point socket on the end of the extension. Bronze hammer. It's like forging. The nut has been heated red so it is loose and the smaller socket is a perfect fit. watch out for fuel fires though.
   / Shop Tricks #7
We use that 12-point socket trick on rounded lug-nuts and lost-key wheel-locks almost daily, except we don't use any heat.
You don't really want to use your favorite socket though, as sometimes driving the socket on the slightly too-big nut will split the socket.:cool:
   / Shop Tricks #8
Air tank and compressor tips :
This one was already posted before this thread started, but it definitely fits into the "tip" category, so here :
http://www.tractorbynet.com/forums/build-yourself/152446-always-ready-portable-air-tank.html
Another one that I finally got around to that I had been meaning to accomplish for probably twenty years; I got it done just this week :
Many is the night that, maybe 1:17 or 2:29 AM, I have been awakened by a noise that definitely ain't the refrigerator kicking on; then I realize I have forgot the compressor ON again and, after a couple weeks, it has bled down enough to kick itself ON.
It don't ever do this during normal hours; always in the middle of the night.
I tied a female plug cut from a Dollar General Store drop-cord to the COLD side of the air-compressor switch; not the pressure-switch, but the switch that powers the whole thing.
I hung a 100-watt bulb in an area that could use a little more light and routed it's cord to the female plug that I had just installed.
I could have used a tiny night-light, or a string of Christmas-tree lights, but lacking either, I opted to just hang the plain old bulb in an area that needed more light anyway.
Now, when the compressor switch is ON, this light is also ON.
When I turn out the shop lights, if there is still one lit, I know what to do, and no more surprises in the middle of the night.:cool:
   / Shop Tricks #9
Bearkiller I have been using the light reminder tip for some time now, but as a reminder to turn off something else. During the winter months when I know I am not going to be in my shop but just for a short time instead of starting a fire in the coal furnace , I will turn my torpedo heater on to break the chill. The bad thing about doing that was that I would forget to turn it off when I left the shop. I use the light as a reminder to turn off the heater, that has saved me several tanks of fuel by not heating the garrage when I am not out there and at about $15 a tank it soon adds up.
   / Shop Tricks #10
Not my picture; thanks to whoever I borrowed it from.:)
This or something similar, with a couple old junk truck-tires roped on, could be employed to push dis-abled vehicles in and out of a shop, or just out of the way for mowing or whatever :
http://www.tractorbynet.com/forums/...154298828-3-pt-pallet-forks-easy-img_0042.jpg
Someone would need be in said vehicle, steering and manning the brakes.
Or, it could be chained up real close, so it couldn't get away from you.
Or, on fairly level ground, one could do like the railroad does when shoving loose cars around, just set the park-brake and push it where you want; when you quit pushing, it will stop.:cool:
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 John Deere TX (A53317)
2018 John Deere TX...
1629 (A57192)
1629 (A57192)
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
Bunker Rake (A59228)
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
