Shop lift, but not for vehicles.
   / Shop lift, but not for vehicles. #11
Is your roof strong enough to bolt on a chain hoist?
   / Shop lift, but not for vehicles. #12
   / Shop lift, but not for vehicles. #14
I’ve came across those on marketplace for cheap. I’ve been tempted to buy one but I don’t have any real use.
You would be surprised the uses you will find. I sometimes clamp an old door to the forks to make an adjustable height table.
Mine also has a wired remote switch so it is handy for holding heavy pieces while you are assembling them, etc.
   / Shop lift, but not for vehicles. #15
I have to admit that I use the bucket or forks on my tractor for the lifting, and work on it outside...
And for us older guys, the light is a lot better out there.
   / Shop lift, but not for vehicles. #16
I've never been in such a hurry that I can't wait for good weather. I lift anything that needs to be "up" with my grapple.
A couple 4x4's wedged thru the lower lid and a half sheet of plywood clamped to the 4x4's works well.
   / Shop lift, but not for vehicles. #17
I keep a polly pallet with a solid surface that I use as a work bench for yard tools etc.
I'm lucky enough to have a small forklift which makes lifting and moving stuff around very easy. One benefit of a worn out back.
   / Shop lift, but not for vehicles. #18
There's the 1000lb motorcycle lift from HF. Little pricey at $550 - $600. Long enough to act as workbench also.
I use a M/C lift. It was pricey as it is "Snap-on" brand. (I didn't buy it new) It is my go-to work bench now. No matter what, it's always the correct height.
It's far cheaper to buy the best tool than to make ANY trip to the doctors!
   / Shop lift, but not for vehicles. #20
Mount a winch. Run the cable through a fully system from the rafters. You can even fab a trolley style runner to push it over after raised.
I have a winch mounted to lift deer in the garage for butchering. I just use the battery from my lawnmower
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
