RSKY
Veteran Member
- Joined
- Oct 5, 2003
- Messages
- 2,447
- Tractor
- Kioti CK20S
I have planned for years to install a natural gas line to my shop and one of those ceiling mounted heaters. I also want a ceiling mounted heater in the garage. BUT, our local gas utility has very, very strict rules on who can install lines and appliances. This probably was caused by a couple of houses exploding a few years ago after the homeowners changed something on their lines. I know both of them. One of the guys told me he opened the door and flipped on the light switch and his next thought, before he passed out, was "Where is my house and why am I looking at the sky?". The other guy's wife was killed in the blast.
Anyway, the cost will be very high to have the gas line run from my house, around a patio, over field tile, under a sidewalk, and to the shop. The heater for the garage would be easy to install. Just run a line up the garage wall and mount the heater. So I am considering having a 240-volt ceiling mounted heater installed in both locations. I think it would take years for the higher cost of the electricity to overtake the cost of installing the gas lines and heaters. The garage heater would be set on 40 degrees and would help keep the utility room warm and the vehicles not as uncomfortable when starting out in them. The shop heater would be set just high enough to keep anything from freezing unless I ventured out there to work on something.
Does anybody have this? How much power is used? Are you satisfied with them? How about the sizing for the shop? It is a 24' x 30' insulated building with an upstairs that I intend to close off.
Thanks for your advice.
RSKY
RSKY
